BASE PLATE DESIGN
sabarinathan99
PostPosted: Tue Feb 28, 2012 7:32 am    Post subject: BASE PLATE DESIGN Reply with quote
Respecetd  Dr. Subramaniam sir,
How do I design the base plate with biaxial bending moment?
PostPosted: Wed Feb 29, 2012 7:19 pm    Post subject: Re: BASE PLATE DESIGN Reply with quote
Dear Er Sabarinathan,
In reality, there is no straight forward solution to this problem. You may convert the BM in the other direction as an equivalent BM in the major direction and design.
Alternatively - analyze one axis a time, and add results from both directions.
Also see the previous discussion in the forum:
http://www.sefindia.org/forum/viewtopic.php?t=6632
The report on Transmission Poles at http://files.engineering.com/getfile.aspx?folder=f5b02f96-7375-437d-a0cd-07bb4679a3b9&file=transmission_poles.pdf
and also the enclosed paper on hexagonal base plates for circular columns may also be useful
sabarinathan99
PostPosted: Thu Mar 01, 2012 4:53 pm    Post subject: BASE PLATE DESIGN Reply with quote
Respected Dr. Subramaniam Sir,
                                              But if we considering wind load at 45 degree there is possibilities of biaxial bending moment in base plate design. Is it correct sir?.  In such cases how can I design?.
JVCSNL
PostPosted: Fri Mar 02, 2012 12:38 pm    Post subject: Reply with quote
Dear Member,
Simplified method is explained by Dr. NS.
Else, you have to use the first principle for biaxial case.  Here, assume the NA at various angles and find out the exact angle of NA and position of NA which will satisfy all equilibrium conditions.
This method will be accurate as it is working on first principle.  But it requires lot of mathematical and requires programming effort.
Jignesh V Chokshi
