Through bolt connection design and cast-in plate design
haisiva
PostPosted: Wed Feb 29, 2012 6:06 pm    Post subject: Through bolt connection design and cast-in plate design Reply with quote
hello friends,
I need a help. I have a steel to concrete column moment connection. the major axis moment is 600kNm.
How i design this connection. i preferred the through bolt connection.
Please any one help me for how to design the through bolt connection.
Is it advisable to give moment in steel to concrete connection? i am not please give reason or article.
by
Sivakumar.
hellowsiva
PostPosted: Thu Mar 01, 2012 4:04 am    Post subject: Through bolt connection design and cast-in plate design Reply with quote
friends,
If any one know. please help
PostPosted: Thu Mar 01, 2012 3:25 pm    Post subject: Re: Through bolt connection design and cast-in plate design Reply with quote
Dear Er Sivakumar,
Refer Guidelines for design of joints between steel beams and reinforced concrete columns, by ASCE committee, published in Aug 1994 issue of the Journal of the Structural Engg. ASCE, Vol.120, No.8, Aug. 1994, pp. 2330-2355
The book "HANDBOOK OF STRUCTURAL STEEL CONNECTIONS DESIGN" by Akbar R.Tamboli, also refers the above paper only. It contains worked examples, which are easy to follow.
Another recent reference based on Japanese practice may be downloaded from http://www.sigi.ca/engineering/civl510_2010/Guidelines%20Seismic%20Design_Nishiyama.pdf
haisiva wrote:
hello friends,
by
Sivakumar.
anshugoel
PostPosted: Thu Mar 01, 2012 3:30 pm    Post subject: Re: Through bolt connection design and cast-in plate design Reply with quote
hellowsiva wrote:
friends,
If it is steel to concrete column (I understood it as steel beam and concrete column),
the anchor bolts need to be tied with the column reinforcing to transfer the moment.
It is a specialist connection. What are the sizes of beams and columns do you have.
There are stepped columns or bracket columns which are frequently used in industrial cranes, etc. You can get a good hint from there.
Also, please provide more information to enable meaningful ideas.
hellowsiva
PostPosted: Fri Mar 02, 2012 3:53 am    Post subject: Through bolt connection design and cast-in plate design Reply with quote
friends,
Thanks for the reply. i will check your references . if i have any doubt i will come back
