No Title
Guest
Guest
PostPosted: Thu Apr 24, 2008 3:01 am    Post subject: No Title Reply with quote
ARC
----- Original Message -----
To:
Sent: Friday, January 23, 2004 11:27 PM
Subject: Bam - BAMBAY
I agree with Dr. Jain that new constructions should be made seismically
safe.
One more point which should be noted is sometimes because of the byelaws /
relaxtion of byelaws produce inefficient structural system.
I will give an example, Bombay Municipal Corporation (BMC) permitts
balcony
area to be enclosed during the construction by paying a premium to be BMC,
it sound good as instead of people enclosing the balconies later (which is
a
common practice in Mumbai) it is done at the stage of design and
construction. But there is a catch the column should not come out upto
the
edge of the balcony, because according to BMC the building line is not the
outer edge of the balcony but the inner edge of the balcony.
The balcony portion even if it is a part of the room has to be designed as
a
cantilever and since it is the part of the room there cannot be a beam
running thro from column to column. Now you have a balcony area which is
resting on a cantilever beam and futher the cantilever beams carry a edge
beam. Further to add agony to the structures architects have slab
projecting
out by 600 to 750 mm with brickwalls on the edges of these cantilever
chajja
projections for the so called ELEVATION_TREATMENT.
Overall now we have a loaded cantilever coming out of the building with
about 900 to 1200 mm for the balcony with live loads + 600 to 750mm for
the
chajja with closely spaced brickwalls as elevation treatment.
As we are aware cantilevers are not good for structures in siesmic zones,
these building structures turn out to be quite inefficient structurally.
Why can the building byelaws simply add a statement that in case the
balcony
is a part of the room the column can be taken at the outer edge of the
balcony. By this simple statement the structure could be safe and
efficient
too.
Vijay Patil
Subject: Malay's question and answer
Date: 25/01/04
Time: 19:45:17
Dear Malay and Bina
regarding expansion joints in the lateral directions in a building, I may remind you that it is predominantly for temperature stresses. The temperature effects are always on the periphery of the building. Especially, the plan area gets heated up and expands. The same effect is not seen on the columns. Hence, the provision is there for expansion joints only in the plan dimensions and not in the vertical direction. One more point to be remembered is that we have a rcc slab element in plan which is directly affected by the heat. In the vertical direction, we do not have any such continuum structural element.
Bimal Shah
M.S.U., Baroda
Subject: Expansion Joints In Buildings.
Date: 24/01/04
Time: 17:00:15
I guess its because there is no restrictions on expansion in the vertical direction whereas in the horizontal direction the support system does not allow the structure to deform thus introducing thermal stresses.
Date: 24/01/04
Time: 17:52:11
I was discussing this with one of my colleague & I am quite convinced by his
reply . Columns or vertical RCC members are subjected to heavy Axial loads
(always) , which acts downwards , so there is no question of Columns
expanding in Vertical direction. Whereas in Beams of Slabs it's not the
case. In case of horizontal members the RCC components can expand or
contract with rise & fall in temperature.
But still there are some minor dimensional changes due to potential impact
of temperature , which can be overcome by appropriate design methods , as we
do while designing Concrete Arch (supporting huge concentrated loads). In
fact in Arch design this temperature effect caters for Major Moments.
Correct me if I am wrong.
Malay
