Building Curve in Plan ! STAAD prob.
malay.kumar at total-e...
Guest
PostPosted: Tue Jan 27, 2004 4:49 am    Post subject: Building Curve in Plan ! STAAD prob. Reply with quote
Hi All,
I am dealing with a project (RCC frame structure) - administrative block ,
which is curve ( rather semicircular ) in plan. Everything is fine except
one problem which I have encountered and I'm unbale to fix the problem.
While doing the Analysis in STAAD-III,  I am very well able to generate the
Structural Frame in it's actual profile (curved). But the point is I can't
feed the Columns in there actual profile. The Columns are neither parallel
to x-axis nor z-axis, rather there profile is such that they are placed in
30 - 60 degrees w.r.t either axis.
All I want to know is that : is there any command in STAAD-III , by which
Columns can be placed in there actual profile ? Not necessary always
parallel or perpendicular to any of the axis.
I hope I am able to put my problem clearly , and expecting some replies at
the earliest.
Malay
Total Environment Building Systems Pvt Ltd, Bangalore, India
