request for clarifying a doubt regarding mix design of Self
ravi_teja
PostPosted: Fri Oct 26, 2012 4:13 pm    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
Hai everyone,
I have been doing my project in Self Compacting Concrete. Among the IEEE journals I collected, 53 grade OPC is only used. Can any one clarify my doubt that only 53 grade OPC should be used or 43 grade OPC can also be used. Awaiting your reply
Thankyou.
SUNEIL
PostPosted: Sat Oct 27, 2012 3:20 am    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
So far as what i have read is that cenment grade 43 and 53 both can be used for SCC.And as per the European guidelines all cements conforming to EN-197-1 can be used for SCC.
Thannks
suneil mehta
ALWAYS  BE POSITIVE !!!!
On Sat, Oct 27, 2012 at 7:48 AM, ravi_teja <forum@sefindia.org (forum@sefindia.org)> wrote:
           Hai everyone,
Thankyou.
anantparghi
PostPosted: Sat Oct 27, 2012 3:53 am    Post subject: Re: request for clarifying a doubt regarding mix design of S Reply with quote
ravi_teja wrote:
Hai everyone,
Thankyou.
Dear Ravi, for self compacting concrete (SSC) you can all kind of cement. If you would use 53 Grade of cement then SCC will give higher strength, but if you use 43 Grade of cement it will give less strength. There is no restriction for grade of cement for SSC. Its depends on what of kind of structure you are going to use as SSC.
Regards !
satheeshhavisa
PostPosted: Sat Oct 27, 2012 4:40 am    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
Hi,
53 Grade concrete will be suitable for RCC structure, even if you are planning to go with Free flow concrete also.
Thanks and Regards,
Satheesh S V
Structural Engineer
Tel: 91-80-66512963
Sent: Saturday, October 27, 2012 7:48 AM
Subject: [SEFI] request for clarifying a doubt regarding mix design of Self Compacting Concrete.
Hai everyone,
Thankyou.
 Filesize:  823 Bytes
 Viewed:  575 Time(s)
satheeshsv
PostPosted: Sat Oct 27, 2012 6:38 am    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thanks and Regards,
Satheesh S V
Structural Engineer
On Sat, 27/10/12, ravi_teja <forum@sefindia.org> wrote:
[quote]
Date: Saturday, 27 October, 2012, 2:18 AM
Hai everyone,
Thankyou.
dipak_bhattacharya
PostPosted: Sun Oct 28, 2012 5:33 pm    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
Dear SEFI members,
Let somebody first clarify what is this cement- grade business ? What is the physics, chemistry and mathematics behind it ? There are thousands of master piece structures constructed all over the world when the concept did not exist. Who has created this business and why every authority is silently accepting it?Why grade 33 has been removed from the market and replaced by only costlier and higher  grades?
Thanks,
Dipak Bhattacharya
[quote]
On Sat, 27/10/12, ravi_teja wrote:
[quote]
Hai everyone,
Thankyou.
anantparghi
PostPosted: Mon Oct 29, 2012 2:32 am    Post subject: Re: request for clarifying a doubt regarding mix design of S Reply with quote
[quote="dipak_bhattacharya"]Dear SEFI members,
Thanks,
Dipak Bhattacharya
[quote]
Hai everyone,
Thankyou.
chirag_baxi
PostPosted: Mon Oct 29, 2012 2:53 am    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
Grade of Cement has always been a mystry of words for marketing purposes.
Well, there is some sense in it which has relation with gaining process of strength over a period of time, but significance wise, it is an individual's perception.
Basically good construction practices only - can get you good quality of concrete. Achiving quality concrete with good density, strength, long life and near impermeability is directly proportional to its prerparation and pacing in forms with laid down procedures and sticking to basics.
As has been rightly said, ancient structures did not have any gradation concept of cement or construction chemicals and still, Taj stands as a glory of India today.
It is unfortunate to note that religiously following the basics in today's time has almost been forgotten. Unless a "Policeman" approach is enforced (barring few exceptions) it is impossible to get the desired involvement of supervisors in the construction activity.
Some times, time constraint also makes a big difference in contribution of the front liners towards quality.
Chirag Baxi
Chief Manager (Civil)
GNFC Ltd.
M: 9724334532, 9825567423
-- Original Message --
Sent: Monday, October 29, 2012 7:48 AM
Subject: [SEFI] Re: request for clarifying a doubt regarding mix design of Self
Dear SEFI members,
Thanks,
Dipak Bhattacharya
To: general@sefindia.org (general@sefindia.org) (general@sefindia.org (general@sefindia.org))
Hai everyone,
Thankyou.
tiach
PostPosted: Mon Oct 29, 2012 3:20 am    Post subject: request for clarifying a doubt regarding mix design of Self Reply with quote
The grade 43 and 53 in cement mainly corresponds to the average
compressive strength attained after 28 days ( 6724 hours) in mega
pascals (Mpa) of at least three mortar cubes ( area of face 50 cm
squared) composed of one part cement, 3 parts of standard s and
( conforming to IS 650:1966) by mass and P/4 ( P is the percentage of
water required to produce a paste of standard consistency as per IS
standard) + 3 percentage ( of combined mass of cement plus sand) of
water , prepared, stored and tested in the manner described in methods
of physical test for hydraulic cement.
721 hr not less than 23 MPa for 43 grade, 27 MPa for 53 grade
1682 hrs not less than 33MPa for 43 grade, 37MPa for 53 grade
6724 hrs not less than 43MPa for 43 grade, 53 MPa for 53 grade
parasravi
PostPosted: Mon Oct 29, 2012 7:55 am    Post subject: different grades of cement Reply with quote
Please see the attached doc file for different grades of cement.
ParasRavi
Difference between 33, 43 & 53 Gr. Cement.doc
 Filename:  Difference between 33, 43 & 53 Gr. Cement.doc
 Filesize:  48.5 KB
 Downloaded:  754 Time(s)
