Difference between Buckling and P-Delta analysis.
Goto page 1, 2, 3  Next
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Er. T. Rangarajan
thirumalaichettiar
PostPosted: Mon Oct 29, 2012 3:52 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
What is the difference between Buckling and P-Delta analysis?
When to use?
T.RangaRajan.
Manoharbs_eq
PostPosted: Mon Oct 29, 2012 7:26 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
Dear sir,
Buckling causes column to deflect form its original position hence a deflected shape has some value delta.
to be clear when a column is loaded it either pails by crushing or by buckling. application of lateral load causes column to buckle.
P-Delta
1) when column deflects from its original position i.e SEP. further when load is applied vertically. vertical load no longer passes through the centroid of column in SEP.
2) when load is applied on deflected column then the column is to face additional moment due to application of load. this effect is called p-Delta. this is a second order effect.
On Mon, Oct 29, 2012 at 9:22 AM, thirumalaichettiar <forum@sefindia.org (forum@sefindia.org)> wrote:
When to use?
T.RangaRajan.[/color:c9eb4c3829]
Rohinton Bhathena
PostPosted: Mon Oct 29, 2012 8:08 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
Dear Thiru,
For example you are analyzing a slender strut such as a Steel Pipe.This pipe is never 100% straight. Therefore you assume a 1/500 eccentricity. Hence a 3m. pipe will be eccentric by 6 mm. If you load this pipe with say 1000kg. An axial force of 1000kg is produced and a bending moment of 1000 x 0.006 = 6 kg.m. The force also produces a deflection d1. So now the eccentricity is 6mm. + d1. This produces another set of calculations. About 3-4 iterations will stabilize the forces. At that time the original 6mm. would have become 6+d1+d2+d3...dn.
For frame structures of critical nature; P Delta analysis gives a more realistic picture. It is time consuming hence it is replaced by extra factored load. Today's computers can perform calculations on hundreds of nodes by the time you read this sentence. So it is worth checking in this manner.
R Bhathena
When to use?
PostPosted: Mon Oct 29, 2012 9:54 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
P-Delta Effect
As a personal thinking,
both the phenomenons are as result of Axial force multiplied with lateral deflection
of member.In one case (P-Delta)member drifts due to global effects under lateral
loading, whereas in other case (Buckling) , the member ends do NOT drift
but , slenderness under own compression load, causes member to buckle .
Global effect of horizontal deflection of members/frames (Drift) as result of
lateral forces (EQ/wind) may cause P-Delta effects in structural members.
A vertical cantilever column of adequate dimensions under heavy load at its top
may not Buckle , but is subject to P-Delta effect due to DRIFT at top under lateral
forces. Similarly a MS building under lateral forces drifts and horizontal deflection
causes P-delta effect in members.
Column subject to vertical load ,due to slenderness , buckles. The P -delta
effect is accounted by reducing the permissible stresses in the member
based on L/R in WSM . In LSM additional moments due to slenderness
are considered.
best regds
vikramjeet
Deepan Shanmugasundaram
PostPosted: Mon Oct 29, 2012 10:53 am    Post subject: Difference between buckling and P-Delta analysis.. Reply with quote
Hi
Simply, to put..
DescriptionBucklingP-Delta
Whats it?A failure modeA method of analysis
Why it's done?To evaluate strengthTo evaluate demand
Buckling:
Buckling is an instability phenomena. It happens when there is a chance for a structural component to behave in an alternate manner for the same load level. (Technically, it said that, its happens at bifurcation point, a point where two equilibrium paths meet).
Intuitively I understand the buckling phenomena by this, "A structure will behave in the easiest way possible, i.e., the behavior which needs less work". That means, say in columns, when the crushing becomes highly demanding, it buckles.
Post-buckling strength can also be considered for design, in components like, plates.
Buckling analysis is needed in almost all the cases of design, since it is a failure mode. The analysis can be omitted (based on engineering judgement) in certain cases (e.g. bulk concrete components) where it is obvious that buckling will not happen prior to other failure modes.
P-Delta Analysis:
P-Delta is an iterative analysis procedure. In typical linear structural analysis, the equilibrium equations are satisfied  at undeformed configurations (exceptions are there: e.g. cables). In p-delta analysis, the equilibrium is considered in the deformed position.
There are two types in it (explained here with ref. to columns):
P- (Small) delta analysis:
Analysis done considering the deformation due to lateral bending of the columns.
P- (Capital) delta analysis:
Analysis done considering the deformation due to lateral swaying of the columns.
I don't have enough experience to tell you about the situations where P-delta analysis becomes necessary. The following are examples..
(1) Sway frames with high axial loads
(2) High plan unsymmetry in live loads
(3) Structures with flexible lateral load resisting systems.. etc
Last edited by Deepan Shanmugasundaram on Mon Oct 29, 2012 12:06 pm; edited 1 time in total
JVCSNL
PostPosted: Mon Oct 29, 2012 11:03 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
Buckling is the effect/resulting effect of members subjected to axial compression loads.
P-Delta analysis is the methodology or consideration of buckling effect into analysis and design of the member subjected to axial compression loads to assess total effect. This analysis also include effect of drifts produced by lateral loads.
Jignesh V Chokshi
Sent: Monday, October 29, 2012 4:22 PM
Subject: [SEFI] Re: Difference between Buckling and P-Delta analysis.
P-Delta Effect
are considered.
best regds
vikramjeet
thirumalaichettiar
PostPosted: Mon Oct 29, 2012 11:08 am    Post subject: Reply with quote
Thanks for your immediate response.
I am not satisfied the with the replies but need more specific and better explanation since need to know when to do them or under what circumstances they should be employed? etc.
Also need to know in depth whether the Buckling and P Delta are related to column only or include for beams also.
Which analysis -First order Elastic,First order Inelastic, Second order Elastic, Second order Inelastic or which analysis is good to get better results?
T.RangaRajan.
Last edited by thirumalaichettiar on Tue Oct 30, 2012 5:21 am; edited 1 time in total
nrupen yadahalli
PostPosted: Tue Oct 30, 2012 5:21 am    Post subject: Difference between Buckling and P-Delta analysis. Reply with quote
P-Delta effect induces additional stresses in structure due to deflection/sway, whereas buckling is a geometric arrangement defining the max stress (may be compresion Strs  may be flexural Strs) can be borne by member based on its compactness and slenderness. For Slenderness-global behaviour or noncompact and below-local behaviour strength reduction will occur in any method WSM or Limit State....
P-delta is only analysis method no reduction in stress/strenght is required if member is non slender n compact.
On Mon, Oct 29, 2012 at 4:22 PM, vikram.jeet <forum@sefindia.org (forum@sefindia.org)> wrote:
  P-Delta Effect
are considered.
best regds
vikramjeet
Manoharbs_eq
PostPosted: Tue Oct 30, 2012 6:27 am    Post subject: Reply with quote
Dear sir,
It is to be very clear, P-Delta analysis is a analysis procedure for vertical supporting system column wall etc.
where as buckling is either local or global effect on the element or structure due to lesser stiffness to withstand own weight and lateral load.
Nonlinear analysis is the procedure for P-delta
buckling and p-delta.docx
 Filename:  buckling and p-delta.docx
 Filesize:  70.8 KB
 Downloaded:  891 Time(s)
zubairmeer1
PostPosted: Tue Oct 30, 2012 10:12 am    Post subject: Reply with quote
Dear rangarajan sir
i was also searching for this answer from quite a few days...and rightly said bu you a  specific answer is required....lets wait and ses NS sirs reply..usually he has to the point answers....and the replies above were also excellent.. i shud accept it was a good piece of learning for me... and above all we require these types of discussions..in the forum....
what i see is P-(small delta) effect also captures this buckling effect so why buckling analysis?
little bit off the topic but.. recently i was going thru past year discussions (2003-2007)...the discussion were of totally different level....and i learnt a lot from those posts...
i request administrator to just give those members a reminder so as to take active part in the discussions and help people like me...
meer
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Er. T. Rangarajan All times are GMT
Page 1 of 3
