Fixing detail of steel bracket
kunal kishor
PostPosted: Sat Dec 01, 2012 6:21 am    Post subject: Fixing detail of steel bracket Reply with quote
Dear Members
I am designing a steel bracket to support the concrete load. This bracket is connected to the RCC core wall.
The bracket has been made of ISMC 150 B/B. For the connection with the wall I have welded the ISMC150B/B with the 25mm thk MS plate using 4mm thk fillet weld. Then this combination is connected with the wall using 18 dia 8.8 grade bolts. For more clarity the diagram has also been attached.
In the connection I am getting a horizontal pulling force of 103Kn and 52Kn of vertical shear force at top support. And at bottom support I am getting 103Kn horizontal compressive force and 52 KN vertical shear force.
I have taken the vectorial resultant of both the forces and design the weld for the resultant force.
I have two major concerns in this
1.) The pulling force acting on the weld is acting perpendicular to the weld axis. In this case my one weld leg is in tension and one leg is in shear. Should I consider the same weld capacity for both the shear and tensile forces or should I consider the different weld capacity for pulling and shear forces.
2.) I have designed the connection as pinned connection. But since I am welding the ISMC section with the plate some moment will induce. So should I consider the joint as fixed and design the weld for moment also
Your valuable inputs are required on the above concern.
Kunal Kishor
bijay sarkar
PostPosted: Mon Dec 17, 2012 4:37 pm    Post subject: Reply with quote
Dear Er Kunal Kishore,
A bracket is a kind of cantilever and it must be moment connected at end. It shall not be considered as pin connection.
I) For transferring shear through the connection, we connect the web by providing web cleat angle.
II) For transferring the moment :
     (a) if the weld is done on ground, flanges (bottom as well as top) are directly welded with complete penetration butt weld.
      (b) if weld is done at erected condition, extra top & bottom plates are used which are fillet welded with the connecting member (bracket) and CPJ butt welded with the connected member.
with regards,
bijay sarkar
kunal kishor
PostPosted: Tue Dec 18, 2012 11:49 am    Post subject: Reply with quote
Dear Er. Sarkar
Thanks for your valuable feedback.
Actually i am directly connecting the bracket(ISMC 200 B/B) with the plate throught the fillet welding.
I am giving the tensile/compressive force genrated by Moment to the flange weld and shear force to the web and length and thickness of weld provided at flange and web are ok to resist the force.
In this case should i give Bottom and Top cover plate.
Kunal
PostPosted: Tue Dec 18, 2012 4:00 pm    Post subject: Reply with quote
Dear Er Kunal,
I have not gone through the fig. in detail.
However, I wish to inform that overhead welding should be avoided, unless you have an experienced welder. The quality of overhead welds will not be as good as in other positions. For some tips for overhead welding, see: http://www.sweethaven.com/sweethaven/BldgConst/Welding/lessonmain.asp?lesNum=7&modNum=7
kunal kishor wrote:
Dear Er. Sarkar
Kunal
kunal kishor
PostPosted: Wed Dec 19, 2012 6:41 am    Post subject: Reply with quote
Dear Sir
Thank you very much for your valuable feedback. I will keep this in mind.
Kunal
