Rehab Code
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 19th July 2004
acpl_sefi
PostPosted: Fri Aug 20, 2004 8:23 pm    Post subject: Rehab Code Reply with quote
Some more thouhts on the rehab code
Sec 7.4.2.1(d) –“ All infill walls shall have a positive connection to the frame to resist out-of-plane forces”. The commentary elaborates that this positive connection could be a “fully grouted bed joint in full contact with the frame or complete encasement  of the frame by brick masonry”!
Reading the main clause I would have thought the code would mean dowels sticking out of the column or beams and embedded into the wall. But this is entirely different. What is the reason that UBC, IBC and other advanced codes (of seismic sensitive countries) have never allowed unreinforced brick masonry. Are we intending to give this practice a clean chit? Are we missing something?
Under dynamic conditions does the bond between mortar and concrete still hold good (knowing they are never monolithic and an old to new cementatious material discrepancy almost always exists).
And what good are brick jackets on concrete columns.
Are there any tests that substantiate these clauses and why aren’t international codes embracing this practise as well.
Sec 7.4.3 & Table 3--Does not talk about effect of lintel bands for height to thickness ratios
Vipul Ahuja
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 19th July 2004 All times are GMT
