Spices for diseases - Worth trying
PostPosted: Mon Jul 29, 2013 4:29 pm    Post subject: Spices for diseases - Worth trying Reply with quote
[quote]    Spices for diseases
COLDS
Mix a gram of dalchini/cinnamon powder with a teaspoon of honey to
cure cold. Prepare a cup of tea to which you should add ginger, clove, bay
leaf and black pepper.. This should be consumed twice a day. Reduce the
intake as the cold disappears.
GINGER FOR COLDS.
Ginger tea is very good to cure cold. Preparation of tea: cut ginger
into small pieces and boil it with water, boil it a few times and then
add sugar to sweeten and milk to taste, and drink it hot.
DRY COUGHS.
Add a gram of turmeric (haldi) powder to a teaspoon of honey for
curing dry cough. Also chew a cardamom for a long time.
BLOCKED NOSE.
For blocked nose or to relieve congestion, take a table spoon of
crushed carom seeds (ajwain) and tie it in a cloth and inhale it.
SORE THROAT.
Add a tea spoon of cumin seeds (jeera) and a few small pieces of dry
ginger to a glass of boiling water. Simmer it for a few minutes, and
then let it cool. Drink it twice daily. This will cure cold as well as
sore throat.
AJWAIN/AJMO FOR ASTHMA.
Boil ajwain in water and inhale the steam.
CURE FOR BACKACHE..
Rub ginger paste on the backache to get relief.
GARLIC FOR HIGH BLOOD PRESSURE.
Have 1-2 pod garlic (lasan) first thing in the morning with water
HONEY AND GINGER FOR HIGH BLOOD PRESSURE.
Mix 1 table spoon and 1 table spoon ginger (adrak) juice, 1 table
spoon of crushed cumin seeds (jeera), and have it twice daily.
MIGRAINE. .
For the cure of migraine or acute cold in the head; boil a tablespoon
of pepper powder, and a pinch of turmeric in a cup of milk, and have it
daily for a few couple of days.
BITTER GOURD/KARELA IS GOOD..
A tablespoon of amla juice mixed with a cup of fresh bitter gourd
(karela) juice and taken daily for 2 months reduces blood sugar.
TURMERIC/ ARAD CURE FOR INJURIES
For any cut or wound, apply turmeric powder to the injured portion to
stop the bleeding. It also works as an antiseptic. You can tie a
bandage after applying haldi/turmeric.
CRAMPS
You must do a self-massage using mustard oil every morning. Just take
a little oil between your palms and rub it all over your body. Then take
a shower. This is especially beneficial during winter. You could also
mix a little mustard powder with water to make a paste and apply this on
your palms and soles of your feet.
HEADACHES.
If you have a regular migraine problem, include five almonds along
with hot milk in your daily diet. You could also have a gram of black
pepper along with honey or milk, twice or thrice a day. Make an almond
paste
by rubbing wet almonds against a stone. This can be applied to forehead.
Eat an apple with a little salt on an empty stomach everyday and see
its wonderful effects. OR When headache is caused by cold winds, cinnamon
works best in curing headache. Make a paste of cinnamon by mixing in
water and apply it all over your forehead
TURMERIC
FOR ARTHRITIS.
Turmeric can be used in treating arthritis due to its
anti-inflammatory property. Turmeric can be taken as a drink other than
adding to dishes
to help prevent all problems. Use one teaspoon of turmeric powder per
cup of warm milk every day. It is also used as a paste for local action.
GOOD FOR THE HEART
Turmeric lower cholesterol and by preventing the formation of the
internal blood clots improves circulation and prevents heart disease
and stroke. Turmeric can be taken as a drink other than adding to dishes
to help prevent all problems. Use one teaspoon of turmeric powder per cup
GOOD FOR INDIGESTION
Turmeric can be used to relieve digestive problems like ulcers,
dysentery. Turmeric can be taken as a drink other than adding to
dishes to help prevent all problems. Use one teaspoon of turmeric powder
per cup of warm milk every day. It is also used as a paste for local
action.
HONEY
HONEY IS A GOOD CURE FOR ALL DISEASES
Mix 1 teaspoon honey with 1 teaspoon cinnamon powder and have at night.
HICCUPS
Take a warm slice of lemon and sprinkle salt, sugar and black pepper
on it.. The lemon should be eaten until the hiccups stop.
HIGH BLOOD CHOLESTEROL
In 1 glass of water, add 2 tbsps of coriander/dhania seeds and bring
to a boil. Let the decoction cool for some time and then strain. Drink
this mixture two times in a day. OR Sunflower seeds are extremely
beneficial, as they contain linoleic acid that helps in reducing the
cholesterol deposits on the walls of arteries.
PILES
Radish juice should be taken twice a day, once in the morning and
then later in the night. Initially drink about 1/2 cup of radish juice and
then gradually increase it to 1 cup. OR Soak 3-4 figs in a glass of water
Keep it overnight. Consume the figs on an empty stomach, the next day
in the morning
VOMITING
Take 2 cardamoms/elachi and roast them on a dry pan (tava). Powder the
cardamoms and thereafter add a tsp of honey in it. Consume it
frequently. It serves as a fabulous home remedy for vomiting. OR In
the mixture of 1 tsp of mint juice and 1 tsp limejuice, add ? tsp of
ginger juice and 1 tsp honey. Drink this mixture to prevent vomiting. OR
Limejuice is an effective remedy for vomiting. Take a glass of chilled
limejuice and sip slowly. To prevent vomiting, drink ginger tea. OR In
1 glass water, add some honey and drink sip by sip.
WARTS
Apply castor oil daily over the problematic area. Continue for
several months. OR Apply milky juice of fresh and barely-ripe figs a
number of times a day. Continue for two weeks. OR Rub cut raw potatoes
on the affected area several times daily. Continue for at least two weeks. OR
Rub cut onions on the warts to stimulate the circulation of blood.. OR
Apply milk from the cut end of dandelion over the warts 2-3 times a
day. OR Apply oil extracted from the shell of the cashew nut over the
warts. OR Apply Papaya juice OR Apply Pineapple juice.
URINARY TRACT INFECTION
In 8 oz of water, put ? tsp of baking soda and drink it. OR Drink
plenty of water, as it aids in flushing out the waste products from the body.
OR Drink Cranberry juice. You can also add some apple juice for taste.
SINUSITIS
Mango serves as an effective home remedy for preventing the frequent
attacks of sinus, as it is packed with loads of vitamin A. OR Another
beneficial remedy consists of consuming pungent foods like onion and
garlic, as a part of your daily meals. OR Fenugreek/methi leaves are
considered valuable.
 Filesize:  18.53 KB
 Viewed:  223 Time(s)
 Filesize:  16.81 KB
 Viewed:  194 Time(s)
 Filesize:  20.57 KB
 Viewed:  193 Time(s)
 Filesize:  33.95 KB
 Viewed:  231 Time(s)
 Filesize:  43.86 KB
 Viewed:  201 Time(s)
 Filesize:  18.21 KB
 Viewed:  219 Time(s)
 Filesize:  11.61 KB
 Viewed:  199 Time(s)
 Filesize:  14.92 KB
 Viewed:  213 Time(s)
 Filesize:  28.79 KB
 Viewed:  193 Time(s)
 Filesize:  19.4 KB
 Viewed:  198 Time(s)
 Filesize:  23.49 KB
 Viewed:  191 Time(s)
 Filesize:  38.84 KB
 Viewed:  188 Time(s)
 Filesize:  14.92 KB
 Viewed:  218 Time(s)
 Filesize:  28.73 KB
 Viewed:  249 Time(s)
 Filesize:  18.5 KB
 Viewed:  219 Time(s)
 Filesize:  20.52 KB
 Viewed:  199 Time(s)
 Filesize:  22.76 KB
 Viewed:  213 Time(s)
 Filesize:  28.72 KB
 Viewed:  200 Time(s)
 Filesize:  20.52 KB
 Viewed:  260 Time(s)
 Filesize:  22.95 KB
 Viewed:  211 Time(s)
 Filesize:  18.51 KB
 Viewed:  192 Time(s)
 Filesize:  34.56 KB
 Viewed:  219 Time(s)
