Shanghai Tower-will become the tallest in China
PostPosted: Fri Aug 02, 2013 5:38 pm    Post subject: Shanghai Tower-will become the tallest in China Reply with quote
Shanghai Tower
The Shanghai Tower is a supertall skyscraper under construction in the Pudong district of Shanghai, China. Designed by Gensler, under its chief architect Peter Weingarten and his Seattle-based team, it will be the tallest of a group of three supertall buildings in Pudong, the other two being the Jin Mao Tower and the Shanghai World Financial Center. Upon its completion in 2014, the building will stand approximately 632 metres high and will have 121 stories, with a total floor area of 380,000 m2
At the time of its completion, the Shanghai Tower will be the tallest building in China, and the second-tallest in the world, surpassed only by the Burj Khalifa in Dubai. It will also become China's tallest structure of any kind, surpassing the 600-m tall Canton Tower in Guangzhou. However, it will be exceeded in height by another Chinese skyscraper, Changsha's Sky City, which is planned to reach a height of 838 m upon its completion in mid-2014!
Planning
Planning models for the Lujiazui financial district dating back to 1993 show plans for a close group of three supertall skyscrapers. The first of these, the Jin Mao Tower, was completed in 1998; the adjacent Shanghai World Financial Center (SWFC) opened in 2008.
Design
The Shanghai Tower was designed by the American architectural firm Gensler with Peter Weingarten as the design director and Jun Xia and Andy Coren as the project-managers-in-charge and Dick Fencl as the lead technical architect and many, many other peoples from many Gensler offices around the world. The tower will take the form of nine cylindrical buildings stacked atop each other, totalling 121 floors, all enclosed by the inner layer of the glass façade. Between that and the outer layer, which twists as it rises, nine indoor zones will provide public space for visitors. Each of these nine areas will have its own atrium, featuring gardens, cafes, restaurants and retail space and providing 360-degree views of the city.
Both layers of the façade will be transparent, and retail and event spaces will be provided at the tower's base. The transparent façade is a unique design feature, because most buildings have only a single façade using highly reflective glass to lower heat absorption, but the Shanghai Tower's double layer of glass will eliminate the need for either layer to be opaqued. Once opened, the tower is expected to accommodate as many as 16,000 people on a daily basis.
In September 2011, the Japanese firm Mitsubishi Electric Corp. announced that it had won a bid to construct the Shanghai Tower's elevator system. Mitsubishi Electric will supply all of the tower's 106 elevators, including three high-speed models capable of travelling at 1,080 m/min – the equivalent of 64.8 km/hour, or 18 m/sec. At the time of their installation in 2014, they will be the world's fastest single-deck elevators (18 m/sec) and double-deck elevators (10 m/sec). The building will also hold the record for the world's furthest-travelling single elevator, at 578.5 m, surpassing the record held by the Burj Khalifa.
When completed, the Shanghai Tower will join the Jin Mao Tower and SWFC to form the world's first adjacent grouping of three supertall buildings. Its Jin Jiang Hotel, located between the 84th and 110th floors, will be the tallest hotel in the world at the time of its completion.
Sustainability
The design of the tower's glass façade is intended to reduce wind loads on the building by 24%. This reduces the amount of construction materials needed; the Shanghai tower used 25% less structural steel than a conventional design of a similar height. As a result, the building's constructors are expected to save an estimated US$58 million in material costs. Though the majority of the tower's energy will be provided by conventional power systems, vertical-axis wind turbines located near the top of the tower will generate up to 350,000 kWh of supplementary electricity per year. The double-layered insulating glass façade is intended to reduce the need for indoor air conditioning, and is composed of an advanced reinforced glass with a high tolerance for shifts in temperature. In addition, the building's heating and cooling systems will use geothermal energy sources.
The owners of the Shanghai Tower, Shanghai Tower Construction and Development, hope to be awarded certifications from the China Green Building Committee and the U.S. Green Building Council for the building's sustainable design.
Construction history
In 2008, the site – previously a driving range – was prepared for construction, and a groundbreaking ceremony was held on 29 November 2008, after the tower had passed an environmental impact study. Construction of the tower will use sustainable techniques to make the building environmentally friendly and reduce energy usage.
By late April 2011, the tower's steel reinforcement had risen to the 18th floor, while its concrete core had reached the 15th floor, and floor framing had been completed up to the 4th floor. A repetitive slip-forming process was used to construct the tower's core floor-by-floor. By late December 2011, the tower's foundations had been completed, and its steel construction had risen above the 30th floor. By early February 2012, the tower's concrete core had risen to a height of 230 m, with around fifty floors completed.
By May 2012, the tower's core stood 250 m high, while floors had been framed to a height of 200 m. By early September 2012, the core had reached a height of 338 m. By the end of 2012, the tower had reached the 90th floor, standing approximately 425 m tall. By 11 April 2013, the tower had reached 108 stories, standing over 500 m tall and exceeding the heights of its two neighbouring supertall skyscrapers, the Jin Mao Tower and the Shanghai World Financial Center. The tower's structure is expected to top out at 632 m in Aug. 2013.
The Shanghai Tower is planned for completion in 2014, but was partially opened to the public in 2012.
Issues
In the first months of 2012, large cracks began appearing in the ground near the tower's construction site. These were blamed on ground subsidence, which was likely caused by excessive groundwater extraction in the Shanghai area, rather than by the weight of the Shanghai Tower. In 2013, it was alleged that the Shanghai Tower, along with numerous other large Chinese buildings, had been constructed with salt-rich concrete – a potentially serious corrosion risk to the tower's structural steel components.
Tail Piece:
Almost as soon as the plan was announced, however, members of the press warned that China was in danger of running afoul of the Skyscraper Index, a 15-year-old theory that correlates the construction of the world's tallest buildings with major economic catastrophe.
Construction for the Empire State Building, for example, broke ground in 1930, in the first months of the Great Depression. The World Trade Center and Sears Tower opened in 1973 during the 1973-74 stock market crash and 1973 oil crisis. The Burj Khalifa finished construction in 2010, right as Dubai started feeling the effects of the most recent global financial crisis.
Source: http://en.wikipedia.org/wiki/Shanghai_Tower
Thankful People
PostPosted: Mon Aug 12, 2013 3:28 pm    Post subject: Re: Shanghai Tower-will become the tallest in China Reply with quote
Also See: http://www.telegraph.co.uk/news/worldnews/asia/china/10216459/Size-doesnt-matter-says-architect-of-Shanghai-Tower.html?fb&goback=.gde_143956_member_262928508
A PDF of this tower is also enclosed.
Shanghai_Tower_12_22_2010.pdf
 Filename:  Shanghai_Tower_12_22_2010.pdf
 Filesize:  5.51 MB
 Downloaded:  812 Time(s)
