Shear Connection in steel structures
rajmohan198512
PostPosted: Wed Sep 18, 2013 5:11 am    Post subject: Shear Connection in steel structures Reply with quote
Can you please send me the following below connection sheets based onAmerican ASD method.<o></o>
<o> </o>
1.Beam to Beam Shear Connection<o></o>
<o> </o>
<if><v> <v> <v> <v> <v> <v> <v> <v> <v> <v> <v> <v> <v> <v> <v> </v> <v> <o></v><v> <v></v><endif><if><endif><o></o>
2. Beam to column flange connection Shear connection<o></o>
<o> </o>
3. Bracing connection Plan Bracing <o></o>
<o> </o>
4. Chevron bracing connection<o></o>
<o> </o>
<if><v> <v></v><endif><if><endif><o></o>
<o> </o>
5. Pinned base plate <o></o>
VPandya
PostPosted: Wed Sep 18, 2013 6:45 am    Post subject: Use the Design Examples (Connections) based on latest AISC . Reply with quote
Dear Er. Rajmohan,
Use the Design Examples (Connections) based on latest AISC Design Manual 14th edition:
DESIGN EXAMPLES
Version  14.1
AMERICAN  INSTITUTE
OF  STEEL  CONSTRUCTION
Chapter IIA
Simple Shear Connections
The design of simple shear connections is covered in Part 10 of the AISC Steel Construction Manual.
Chapter IIB
Fully Restrained (FR) Moment Connections
The design of fully restrained (FR) moment connections is covered in Part 12 of the AISC Steel  Construction Manual
Chapter IIC
Bracing and Truss Connections
The design of bracing and truss connections is covered in Part 13 of the AISC SteelConstruction Manual.
Chapter IID
Miscellaneous Connections
This section contains design examples on connections in the AISC Steel Construction Manual that are not covered in other sections of the AISC Design Examples.
These examples are in both LRFD (Limit State) and ASD.  You can get a copy these examples book from AISC Book Store.  I have a copy but for AISC copy protection rights, I can not send it to you.
Regards.
Vasudeo Pandya P.E. ; S.E.
Structural Engineer
