Daily Digest Sat Jul 24 23:00:02 2004
ibarua
PostPosted: Sun Jul 25, 2004 3:34 am    Post subject: Daily Digest Sat Jul 24 23:00:02 2004 Reply with quote
25 July, 2004
Re.: Punching shear
It is the beam or the slab and NOT the column that has to sustain shear. If the beam or slab is safe against shear, then you have nothing to worry. At a junction of a column-slab system, without supporting beams, such as a flat slab, shear becomes critical for design.
The term 'punching shear' is usually applied to shear cause by a concentrated load on a thin member like a slab. A foundation footing may fail by punching shear; so can a flat slab (a slab suppported directly on columns)even under a UDL, or the deck slab of a bridge subjected to a concentrated load like a wheel load.
Indrajit Barua
Guwahati, Assam.
(ibarua@deguild.com)
On Sat, 24 Jul 2004 general@sefindia.org wrote :
[quote]---------------------------------------------------------
