Daily Digest Tue Aug 10 23:00:03 2004
jydesai1
PostPosted: Wed Aug 11, 2004 5:34 am    Post subject: Daily Digest Tue Aug 10 23:00:03 2004 Reply with quote
Dear Hiren
If it is raft footing, yes we need not have the movement joint thru it. But where rafts are not provided, and where foundation-soil is susceptible to significant settlements, it is better to have independent footings to avoid undesirable forces due to differential movements in superstructure.
J.Y.Desai
-----Original Message-----
Message From  general@sefindia.org [mailto:general@sefindia.org]
Sent: Wednesday, August 11, 2004 4:30 AM
To: J. Y Desai
Subject: Daily Digest Tue Aug 10 23:00:03 2004
Message From  saistructure@rediffmail.com
Subject: Common Footing for buildings column seperated for movement joints
Date: 10/08/04
Time: 10:15:11
Dear friends,
Can we have common footing for columns of buildings, which are seperated by movemement joints of about 3;quot;(75mm)?
Hiren Desai
Message From  rudra_nevatia@yahoo.com
Date: 10/08/04
Time: 13:58:58
yes!
--- saistructure@rediffmail.com wrote:
Dear friends,
Hiren Desai
Structural Engineers Forum of India
providers!
Message From  civil@garwarepoly.com
Subject: Common Footing for buildings column seperatedfor
movement    joints
Date: 10/08/04
Time: 14:41:06
Dear friends,
Can  we know vibration measuring device for structure by indian manafacturing
company.
Thanks,
Ravi Joshi
Message From  narzi@satyam.net.in
Date: 10/08/04
Time: 16:59:48
Dear Hiren,
Design a single foundation with TWIN column - Design it like a combimed
footing - cg needs to be maintained of footing with center of load -
Kamal
----- Original Message -----
To: narzi@satyam.net.in
Sent: Tuesday, August 10, 2004 10:15 AM
joints
Dear friends,
Hiren Desai
Date: 10/08/04
Time: 20:09:23
Dear Kamal,
You have not interpreted my question correctly, still let me know how you will calculate C.G. for two columns having diffren axial loads, Mx and My and these values are diffren for 21 loadcases.
Hiren Desai;nbsp;
ibarua
PostPosted: Wed Aug 11, 2004 12:58 pm    Post subject: Daily Digest Tue Aug 10 23:00:03 2004 Reply with quote
11 August, 2004
One footing may accommodate 2 columns separated by a joint for movement. The footing has to be designed for the loads and moments from the two columns.
Indrajit Barua.
On Tue, 10 Aug 2004 general@sefindia.org wrote :
[quote]---------------------------------------------------------
sdec.in
PostPosted: Wed Aug 11, 2004 1:26 pm    Post subject: Daily Digest Tue Aug 10 23:00:03 2004 Reply with quote
Well the footing has to carry the loads of both the footings , this is
acceptable, but the original question was whether it is practical or is
it necessary to insist that moments from all the load cases be also
checked for and that is where the engineer's decision and judjement
lies.Many people have always checked only for DL+ll whereas many clients
insist that all the load combos for all the columns be checked and many
a times, the client wins and u hav to do it that way. It is only here
that Vipuls reasoning makes lot of sense to me.
Sangeeta wij
Message From  ibarua@deguild.com [mailto:ibarua@deguild.com]
Sent: Wednesday, August 11, 2004 6:35 PM
To: sdec@bol.net.in
11 August, 2004
columns.
Indrajit Barua.
vandana_bimal
PostPosted: Thu Aug 12, 2004 1:43 pm    Post subject: Daily Digest Tue Aug 10 23:00:03 2004 Reply with quote
Dear Mr. Hiren Desai
Yes, you can and actually must provide a common footing for columns
seperated by an expansion joint of 75mm. In fact, below the ground level you
can have a common pedestal which will act as a single column pedestal. If
you have different axial loads on each column above the ground level, their
footing has to be designed for one worst load case and checked for other
combinations.
Bimal Shah
Date: 10/08/04
Time: 20:09:23
Dear Kamal,
Hiren Desai;nbsp;
