Load Cases for Footing Design
mc.upadhyay1
PostPosted: Wed Aug 11, 2004 11:50 am    Post subject: Load Cases for Footing Design Reply with quote
Hello
i think we should check the footing for both the cases;
a) for max load and corresponding moments
b) for maximum eccentricity (ratio of M/P)
any case may give maximum bearing pressure.
Mukesh Upadhyay
rr_vemuri@rediff
mail.com                 To:      mc.upadhyay@jil.co.in
cc:
08/11/04 11:44           Subject: Common Footing for buildings column    seperated
AM                       for movement joints
Please respond
to general
Dear friends,
We have made a spread sheet programme in EXCEL to consider the critical
case to find maximum ecc. of all the load cases for each direction and
design the footing for maximum eccentricity of both directions and apply it
as if the same ecc. will be applicable for both cases. After having found
that large ecc occur in seismic cases , we have adopted the case of Maximum
load and corresponding eccentricity.- rangarao
