earthquake
md zeeshan ali
Progressive Member
Progressive Member
PostPosted: Thu Nov 14, 2013 2:28 pm    Post subject: earthquake Reply with quote
dear SEFI members
how to find the negative bending moment capacity of the beam section?
in all the concrete books that i have, only positive bending moment capacity formulla of doubly reinforced section is given.
pls help me.....
PostPosted: Fri Nov 15, 2013 7:57 pm    Post subject: Re: earthquake Reply with quote
Assume that the beam is reversed and use the same formula! But note that you should not consider T-beam action near supports which will be subjected to neg. moment!
md zeeshan ali wrote:
dear SEFI members
pls help me.....
md zeeshan ali
Progressive Member
Progressive Member
PostPosted: Sat Nov 16, 2013 2:05 pm    Post subject: Re: earthquake Reply with quote
dear SEFI members
pls help me.....
dear Dr. N. Subramanian
very very thanks . i am not expecting that such a great person will answer my silly question. many many thanks again.
I have tried that but by doing so i am getting negative neutral axis depth, as the steel in compression in more than the tension.
the below pdf (on page 9) ask to ignore the compressive steel, but i have not seen these assumption in the code(is 456 or is 13920). will this be correct?
guide me...
Examples on 13920.pdf
 Filename:  Examples on 13920.pdf
 Filesize:  1.18 MB
 Downloaded:  1728 Time(s)
PostPosted: Mon Nov 18, 2013 4:13 am    Post subject: Re: earthquake Reply with quote
Dear Er Zeeshan Ali,
When beams are subjected to reversal of stresses, designers generally design them separately for sagging (Positive) and hogging(negative) moments and provide reinforcements at the appropriate face of the beam. Hence the assumption made in quoted reference (pp.9) is usual practice only.
Best wishes,
guide me...[/quote]
md zeeshan ali
Progressive Member
Progressive Member
PostPosted: Mon Nov 18, 2013 5:29 pm    Post subject: Reply with quote
THANK YOU VARY MUCH FOR YOUR PRECIOUS HELP TO ME.
MD ZEESHAN ALI
