hellowsiva SEFI Member
Posted: Fri Feb 28, 2014 3:47 am Post subject: Reg Concrete Bearing strength |
hello,
i am designing base plate for the steel column. Maximum allowable base plate size is 520x520mm.
Concrete grade is M40.(Fck=40N/mm^2)
Minimum Required Base plate size 820x820mm as per the concrete bearing strength.
Force/(0.6*Fck)
please any one help how to increase the concrete bearing capacity without increase base plate size and Concrete grade.
by,
siva |
