Torsional Analysis
mangeshb
PostPosted: Fri Oct 01, 2004 6:58 am    Post subject: Torsional Analysis Reply with quote
Hi ,
i am woking on certain Industrial building for torsional analysis due to
irregular plan and elevation of building and its behaviour in earthquake
condition.
i have referred the "explanatory examples on IS 1893(Part 1)2002" - a
draft code .
but i am facing problem while calculating the design eccentricity edi.
Pls tell me how to work out this one.
Any suggestion will really help but with quick response.
Mangesh B.
Design Excellence (India) Pvt Ltd, Thane, India
Sent using PostMaster by QuantumLink Communications Pvt Ltd
mangeshb
PostPosted: Fri Oct 01, 2004 7:00 am    Post subject: Torsional Analysis Reply with quote
Hi ,
condition.
draft code .
Mangesh B.
Rudra Nevatia
PostPosted: Fri Oct 01, 2004 9:35 am    Post subject: Torsional Analysis Reply with quote
Mangesh,
I have just uploaded a note on seismic design of buildings at
http://rudranevatia.com/verify.htm which may help you.
Although the included design example is for a symmetrical building,
the design note gives sufficient information on treatment of asymmetry.
This note is still in 'proof reading' stage.
Rudra Nevatia
--- mangeshb@designexcel.com wrote:
Hi ,
condition.
draft code .
Mangesh B.
providers!
rsmengr at eth.net
Guest
PostPosted: Fri Oct 01, 2004 1:06 pm    Post subject: Torsional Analysis Reply with quote
Hello Mangesh:
Some how this message didn't appear.
Rajiv
mangeshb
PostPosted: Fri Oct 01, 2004 2:42 pm    Post subject: Torsional Analysis Reply with quote
hello Rajiv
i had gone thru ur mail.now i am sending my querry in detail.
I am actually working on One Industrial bldg. for torsional analysis
and design. For that i have referred "explanatory examples on
IS1893(PART1):2000"-a draft code.
But in the calculation of design eccentricity (edi), as per clause 7.9.1
IS1893 ,
1.5esi+0.05bi
edi=  or
esi-0.05bi
whichever cause worse change in shear.
But we have been suggested to deduct 1.0 esi for certain reason (not
knowing).
we hav done analysis in STAAD as space frame structure.
So can anybody will tell me how this 1.0esi been dedected from eq. and why..
or else pls tell me the detailed procedure with typical example for
sysmmetrical and unsymmetrical structure (as perTable 4&5) IS1893).
thanks
Mangesh B.
mangeshb
PostPosted: Fri Oct 01, 2004 4:12 pm    Post subject: Torsional Analysis Reply with quote
IS1893 ,
1.5esi+0.05bi
edi=  or
esi-0.05bi
in which case second cl. will govern...?
Mangesh B.
swet662003
PostPosted: Sat Oct 02, 2004 6:54 am    Post subject: Torsional Analysis Reply with quote
Dear Mr. Mangesh
I think Staad Took account Eccentricity autonmatically but do not consider Torsional Accidental Ecc. which is 0.05e as specified in the code. Hence you were told not to consider 1.0e and work around with accidental ecc alone.
Another way out to such analysis, people come around is they increse forces arrived after analysis by adhoc 5-10% to tackkle teh accidental ecc.
Hope this will help you.
Makarand
hello Rajiv
IS1893 ,
1.5esi+0.05bi
edi= or
esi-0.05bi
knowing).
thanks
Mangesh B.
anandrshah9
PostPosted: Sun Oct 03, 2004 12:59 pm    Post subject: Torsional Analysis Reply with quote
Dear Mr. Makarand,
Though Staad took account eccentricity automatically as per manual of staad,
some things
need to be varify.
Center of Rigidity of the particular floor
Positiion of Master node in case of Master Slave option
Bcs such clarification and details are not provide in STAAD.
& Increase in shear force will be there in some portion of that particular
floor.
Anand
Message From  swet662003@yahoo.com
Reply-To: general@sefindia.org
To: anandrshah9@hotmail.com
Subject: Torsional Analysis
Date: Sat Oct  2 12:24:43 2004
Dear Mr. Mangesh
alone.
Makarand
hello Rajiv
IS1893 ,
1.5esi+0.05bi
edi= or
esi-0.05bi
knowing).
why..
thanks
Mangesh B.
vote.yahoo.com - Register online to vote today!
_________________________________________________________________
Win a trip to Singapore! http://eu.xmts.net/80450 Experience the magic!
h2003128
PostPosted: Mon Oct 04, 2004 6:39 am    Post subject: Torsional Analysis Reply with quote
Hello!!! all sefians!!
I am Srikanth doing my Masters in Structural engg. as a part of project
thesis I am working on "seismic behavior of fiber reinforced soils" giving
importance to foundations if at all there is any mathematical/analytical
/numerical model that can be made for analysis on this topic or any
references for establishing  such model please let me know.
Thanx in advance
srikanth
