ETABS: Modelling an L-column in Section Designer
Abhishek_Singh
Bronze Sponsor
Bronze Sponsor
PostPosted: Thu Nov 18, 2010 6:36 am    Post subject: ETABS: Modelling an L-column in Section Designer Reply with quote
I was trying to model an L-column in ETABs through the "section designer" application of ETABS. I have two queries regarding that:
1. How to model the actual condition wherein two perpendicular beams will rest on two orthogonal legs of an L-column (which is the corner column of the building) ?
2. What is the significance of the "insertion point" and how to move the c.g. of the L-section to the insertion point. Please note that in the L-section the since the c.g. lies outside the section I am not able to click on the c.g. and drag it to the insertion point using "reshaper tool".
  Also, please explain( if anyone is kind enough to ) the significance of two axes shown in the "section designer" window. One is the XY axis (shown in green) and the other is the 2-3 axis shown in red? Initially both the axes stand together but after I create the L-section the axes separate out, that is, they move away..
Thank you,
Abhishek Singh
paresh_patel
PostPosted: Sat Aug 16, 2014 9:14 am    Post subject: Reply with quote
Dear abhishek sir.
    I am facing same problem. If u found any solution then please post.
Thank you.
