design of L-COLUMN
mangeshb
PostPosted: Mon Oct 18, 2004 3:47 am    Post subject: design of L-COLUMN Reply with quote
Hello sefians,
i am supposed to work out the design of L-column due to architectural
requirement.
I am in urgent need of Help on this topic.
Any information or suggestion will really prove benificial,if any.
Mangesh B.
Design Excellence (India) Pvt Ltd, Thane, India
Sent using PostMaster by QuantumLink Communications Pvt Ltd
Rudra Nevatia
PostPosted: Mon Oct 18, 2004 4:12 am    Post subject: design of L-COLUMN Reply with quote
Dear Mangesh,
Here are some good references for non-rectangular columns:
1. Mallikarjuna and P.  Mahadevappa [1992] Computer Aided Analysis of
Reinforced Concrete Columns Subjected to Axial Compression and Bending I- L
Shaped Sections, Computers & Structures, Vol. 44 No. 5
2. Sinha, S.N. [1996] Design of Cross (+) Section of Column, Indian Concrete
Journal, March 1996
There are several papers and a book published by Prof. Sinha on the subject.
If you prefer a software for doing the calculations, you may look for IRRCOL
and GaLa on the Internet.
Demo version of DOS based program ARCI can be downloaded from
http://rudranevatia.com/arcidemo.zip
Hope that helps.
Rudra Nevatia
--- mangeshb@designexcel.com wrote:
Hello sefians,
requirement.
Mangesh B.
secspl
PostPosted: Mon Oct 18, 2004 4:23 am    Post subject: design of L-COLUMN Reply with quote
Dear Mangesh,
Check out the interaction charts for design of L & + shaped columns in a
text book on RCC design by Prof Sinha (probably from IIT Kanpur), published
by Tata-McGraw Hill. The charts are a bit cumbersome to use, but will
probably sort out your immediate problem.
Ramnath Shenoy
----- Original Message -----
Message From  <mangeshb@designexcel.com>
To: <secspl@blr.vsnl.net.in>
Sent: Monday, October 18, 2004 9:06 AM
Subject: design of L-COLUMN
Hello sefians,
requirement.
Mangesh B.
sdec.in
PostPosted: Tue Oct 19, 2004 4:55 am    Post subject: design of L-COLUMN Reply with quote
dear mangesh,
if u are using staadpro, u will be required to feed the cross-sectional
area, and moments of inertia for this section for the analysis stage.
However, if u are handling it manually, maybe an approximation will be to
try and find an equivalent rectangle or square(also match the M.I. as far as
possible with that of the actual section)
After this u can use prof Sinha's book for the structural design.
Sangeeta Wij
To: <sdec@bol.net.in>
Sent: Monday, October 18, 2004 9:27 AM
Hello sefians,
requirement.
Mangesh B.
