SHS(BEAM) to LGS Truss Connection
ArstA
PostPosted: Sat Feb 14, 2015 11:07 am    Post subject: SHS(BEAM) to LGS Truss Connection Reply with quote
Hello everybody!
I will be very thankful if somebody helps, the main scheme is attached at the post.
As you can see My light gauge steel(Thin walled) truss is fixed to the Square hollow section(BEAM).
To connect Square Hollow Section (BEAM) to LGS truss in 1 side I use 2 angles near edges and fix them with screws or bolts..(see file attached)
Q: My scheme is correctly selected for this situation?
I choose 4 pin supports as you can see in the scan, maybe slide supports needed somewhere? What do you think?
Thank you
scan0011.pdf
Truss to Beam
 Filename:  scan0011.pdf
 Filesize:  90.93 KB
 Downloaded:  265 Time(s)
