STAAD_COLUMN DESIGN_RF DISTRIBUTION_RFACE COMMAND
maulesh
PostPosted: Thu Jul 16, 2015 1:31 am    Post subject: STAAD_COLUMN DESIGN_RF DISTRIBUTION_RFACE COMMAND Reply with quote
Presently we are working on high rise tower. Building is analyzed using STAAD & design is also done through STAAD. In column design, we need to mentioned Reinforcement distribution (equally distributed on all four sides, 2-face distribution about major axis & 2-face distribution about minor axis). As i have rectangle column, i used Rface-2 (which indicates 2-face distribution about major axis). However, if we see detail results (using Track-9 command), it is observed that reinforcement is arranged equally on other face of column. It is depend on local z axis of member.
Please find attached word documents showing reinforcement design for two columns. Please note column no 1266 & 1393 having orientation in orthogonal direction. Please give valuable suggestion & guidance for same.
Thanks lot,
C O L U M N N O 1266_STAAD RESULT.doc
 Filename:  C O L U M N N O 1266_STAAD RESULT.doc
 Filesize:  56.5 KB
 Downloaded:  260 Time(s)
C O L U M N N O 1393_STAAD RESULT.doc
 Filename:  C O L U M N N O 1393_STAAD RESULT.doc
 Filesize:  57 KB
 Downloaded:  224 Time(s)
