IS code for Multistoried Building Frame analysis
udayakumar
PostPosted: Fri Jul 10, 2015 7:39 am    Post subject: IS code for Multistoried Building Frame analysis Reply with quote
Similar to IS 456 and SP 16 for Concrete design, is there any IS code / Handbook for guiding Multistoried Building Frame 3D analysis?
Thankyou for your reply in advance.
Best Regards
R.Udayakumar.
VPandya
PostPosted: Sun Jul 12, 2015 4:13 pm    Post subject: No code on 3-D Structural Analysis of High Rise Bldg. Reply with quote
Dear Er.  Uday Kumar,
We in US divide applicable code for a building project this way:
Governing Building Code: IBC ( International Building Code) 2014.   This tells you
     about  Live Loads, Wind Loads, Earthquakes Loads, Fire Rating ( Fire Load), Drift ( Deflections) limits and things like that.  This code in turns referrer to current  applicable MATERIAL CODES  like  AISC (Steel) , ACI ( Concrete).
Neither   BUILDING  CODES (IBC)  or  MATERIAL CODES ( AISC, ACI) will tell you how you do a 3-D High  Rise  Building Analysis.  Codes will give you DRIFT LIMITS  and  P-DELTA effects, Progressive Collapse Requirements,  but will not tell you how we do our High Rise Building Analysis. In Concrete High Rise Building 3-D analysis we have to consider  CRACKED SECTION PROPERTIES for  BEAMS and COLUMN ELEMENTS ( ACI Code).
In 3-D Analysis of High Rise Bldgs., we engineers are on our own . Only help I got was from my LEAD STRUCTURAL ENGINEER  on the project.
Vasudeo Pandya  P.E. ; S.E.
Structural Engineer
yadavenkatesh
PostPosted: Mon Jul 13, 2015 10:55 am    Post subject: Modeling Assumptions Reply with quote
Hi, Please find attached SP guide lines on the subject.
SP240-1-Modellingassumptionsforlateralanalysis.pdf
Attached SP will help you to some extent on the subject.
 Filename:  SP240-1-Modellingassumptionsforlateralanalysis.pdf
 Filesize:  1.26 MB
 Downloaded:  681 Time(s)
udayakumar
PostPosted: Fri Jul 17, 2015 8:54 am    Post subject: Reply with quote
Dear Sir
Thankyou Pandya sir and Yadavenkatesh sir. Sorry for the late reply as I was unable to login to the forum for quite some time recently.
Best Regards
R.Udayakumar.
