Support Condition For Movable Steel Shelter with Wheel Arran
karthick_ce
PostPosted: Fri Jul 31, 2015 3:59 am    Post subject: Support Condition For Movable Steel Shelter with Wheel Arran Reply with quote
Good Morning. I need to design a temporary covered fabrication yard. Its a duo pitched steel truss shelter supported with wheel arrangement on steel columns.The shelter also supporting 2 nos of 20Tons cranes. The gable end are open and side walls are covered with metal sheet. How will be the shear force perpendicular to the rail will transfer from column to foundation? What will be the support condition to be taken care for analyzing the shelter?
Steel Column With Wheel arrangement.pdf
The wheel can transfer Vertical force, Shear force parallel to rail from column to the foundation.
 Filename:  Steel Column With Wheel arrangement.pdf
 Filesize:  888.97 KB
 Downloaded:  468 Time(s)
