Shear Strength of Columns ( REPEAT)
iyer_mahadevan at redi...
Guest
PostPosted: Mon Nov 22, 2004 9:50 am    Post subject: Shear Strength of Columns ( REPEAT) Reply with quote
Dear SEFIANS!
For evaluating the design shear strength of columns (taucee)
should we consider the entire crosssectional steel?.
The table in IS456-2000 for the same gives taucee vs. p(percentage tensile reinforcement)which is alright in case of beams(singly reinforced).
In case of columns since the steel in the entire cross section resists the bending moment, I feel the percentage p should be evaluated taking the total steel.
The table above may not be valid then!
Kindly clarify.
MAHADEVAN IYER
mc.upadhyay1
PostPosted: Mon Nov 22, 2004 12:36 pm    Post subject: Shear Strength of Columns ( REPEAT) Reply with quote
Hello Mr Iyer
The table between shear strength of conc. & %age of tensile
reinforcement
is equally applicable to doubly reinforced beams too; because it is only
one face of the beam
reinf.  which is in tension, other face of reinf. is in compression.
For columns you have to consider the reinf. which is in tension for a
particular direction of
shear force not the total reinf. .
Mukesh Upadhyay
iyer_mahadevan@red
iffmail.com                To:      mc.upadhyay@jil.co.in
cc:
11/22/04 04:09 PM          Subject: Shear Strength of Columns ( REPEAT)
Please respond to
general
Dear SEFIANS!
total steel.
Kindly clarify.
MAHADEVAN IYER
