Testing of concrete cubes of different thickness
sidhudaljeet
PostPosted: Tue Nov 23, 2004 5:55 pm    Post subject: Testing of concrete cubes of different thickness Reply with quote
Dear Friends
Generally we test the concrete cubes of 150mm x 150mm x 150mm for compressive strength. If  we cut a piece from slab or any other member say paving block etc.  the thickness may vary from 150 mm and this would effect the results. Is there any relation between size of cube and compressive strength, as it is in case cubes and cylinders.
Daljeet Sidhu
suraj
PostPosted: Fri Nov 26, 2004 4:56 am    Post subject: Testing of concrete cubes of different thickness Reply with quote
When a practical test is to be conducted for hardened concrete from any mamber, a core is drilled out & tested according to provisions of code to evaluate the strength. That value is further converted to equivalent cube strength & the acceptable limit of acceptance criterial is 85% value of the characteristic design strength of the concrete. I have conducted the cores tests many times. Also the load test can be conducted using cyclic method to ascertain the load carrying capacity of the concret.
Eng Suraj Singh PE
Doha Qatar
sidhudaljeet@yahoo.com wrote:
Dear Friends
Daljeet Sidhu
The all-new My Yahoo! Get yours free!
