A simple question about steel section properties
Robert.Nicolson at Sub...
Guest
PostPosted: Wed Nov 24, 2004 11:16 am    Post subject: A simple question about steel section properties Reply with quote
ěCan someone plese tell me whether an angle, i.e. a L shape has a plastic
neutral axis.
Because I have just used a program which gave me Zpl,x & Zpl,y ( second
moment of areas ),
as both equal to 0, for an angle ?
Rudra Nevatia
PostPosted: Thu Nov 25, 2004 9:41 am    Post subject: A simple question about steel section properties Reply with quote
Intutively, for an equal leg angle, plastic neutral
axes should be located close to the legs.
Rudra Nevatia
--- Robert.Nicolson@Subsea7.com wrote:
shape has a plastic
neutral axis.
moment of areas ),
http://mobile.yahoo.com/maildemo
kalyan
PostPosted: Fri Nov 26, 2004 4:18 am    Post subject: A simple question about steel section properties Reply with quote
Plastic neutral axis are calculated by equating total area in tension to
be equal to the total area under compression about the two principal
axes, which in the case of equal angles are UU nad VV axes.
Kalyanaraman
Rudra Nevatia
shape has a plastic
neutral axis.
moment of areas ),
