expansion joint and sepration gap
padamkr1
PostPosted: Mon Dec 06, 2004 5:28 pm    Post subject: expansion joint and sepration gap Reply with quote
DEAR  SEFIANS,
HELLO !
I WOULD LIKE TO CLARIFY  THE FOLLOWING POINTS REGARDING EXPANSION JOINT/SEPARATION GAP IN A MULTISTOREYED BLDG.
- IS IT NECESSARY TO PROVIDE EXP JOINT IN RAFT AND RETAINING   WALLS  ALSO IN A DOUBLE BASEMENT OF 15 STOREYED BLDG..
-WHAT PRECUTIONS SHOULD BE TAKEN  IF EXP JOINT IS NOT PROVIDED IN 70 MTR LONG BLOCK OF A BLDG . DOES WIDTH OF BLDG PLAY ANY PART IN DECIDING THE LOCATION OF EXP JOINT
- SEPRATION  GAP AS PER  IS-1893 -2002 SHOULD BE R TIMES THE  MAX DEFLECTION  (R/2+R/2)  FOR TWO BLOCKS . SOMETIMES IT COMES OUT TO BE 300 MM , IS IT PRACTICABLE  TO PROVIDE/TREAT  THIS MUCH WIDTH  OF JOINT?
THANKS
PADAM KUMAR
DELHI
padam kumar
suraj
PostPosted: Tue Dec 07, 2004 4:46 pm    Post subject: expansion joint and sepration gap Reply with quote
Expansion/Movement Joint – Buildings
It is very specific question but the answer is not very specific
Since it is the monolithic slab area used in the design  of the 3 dimensional analysis of the proposed structure that shall dictate the empirical understanding of the location of the movement joint in any buildings as well as the number of the joints continuity
To my understanding it is the experience & concept of the engineer’s design capability to decide how many square meters of the slab area is permissible to form the joint in continuous structures particularly up to multistory class
The rafts may be given movement provision but not essential
Columns in both structures can be given the joint but footing can be one for  two columns/combined
Generally 900 to 1000 sqm is the limit but due to improved quality & grading of the concrete & controlled use, the area may be increased keeping the other building distant to let the building adopt sway action due to seismic stresses
Should u depend on the code formula or some other formula, I have no comments since codes cannot solve all engineering problems. Engineering rests with individual intelligence & concept
Eng Suraj Singh PE
Doha/Qatar
padamkr@yahoo.co.in wrote:
DEAR SEFIANS,
HELLO !
THANKS
PADAM KUMAR
DELHI
padam kumar
Yahoo! India Matrimony: Find your life partneronline.
