Base Condition For RCC building in ETABS
Deepthi Darla
PostPosted: Tue Sep 06, 2016 6:10 am    Post subject: Base Condition For RCC building in ETABS Reply with quote
While designing a Multi Storeyed RCC building with Lateral loads what is the preferable base conditions to be given for columns? (Hinged or Fixed)
If a fixed condition is given are footings to be designed for the base moment also? Because with high earthquake load the base moment is very high and footing becomes uneconomical.
Raza_Ahsan
PostPosted: Tue Sep 06, 2016 9:11 am    Post subject: Re: Base Condition For RCC building in ETABS Reply with quote
You have to provide a Fix Support to the column at the base and footing will design accordingly.
BVRAO
PostPosted: Tue Sep 06, 2016 3:12 pm    Post subject: Re: Base Condition For RCC building in ETABS Reply with quote
[quote="Raza_Ahsan"]You have to provide a Fix Support to the column at the base and footing will design accordingly.
Yes
saikiran gone
PostPosted: Fri Sep 09, 2016 8:53 am    Post subject: Reply with quote
Hi Deepthi Darla,
You can model the structure with pinned connections, but the structure should safe in lateral deflection criteria. You should provide a connection with foundation detailing should be Pinned such that it should transfer axial load only no moment. Providing such connection in the site is not  preferable.
So, it's better to consider the column base as fixed and design the foundation for respective moments and axial force.
with best,
Saikiran.
PPK
PostPosted: Sat Sep 10, 2016 6:02 am    Post subject: Base condition of a RCC framed structure Reply with quote
Kindly refer to clause No. 3.15.1 of Reynolds RCC designer's handbook (10th edition)where the end condition considerations for a framed structure are clearly explained.
