rajeshsuraypally General Sponsor
Posted: Sat Dec 10, 2016 3:07 pm Post subject: which type of foundation should recommend for SBC of 5t/m2 clay soils....? |
sir,
I am a fresher to structures please suggest me a best suitable foundation type for a SBC of 5t/m2 clay soils.
thanks in advance. |
es_jayakumar General Sponsor
Posted: Sun Dec 11, 2016 6:30 am Post subject: |
Dear Er. Rajesh,
For ascertaining the suitable type of foundation, you have to specify if the structure is load bearing or framed. If framed, the magnitude of axial load load transmitted through columns will decide the foundation, viz., end bearing pile, under-reamed pile, mat foundation, combined footing or isolated footing. The low SBC in your case may necessitate pile foundations for taller structures.
E S Jayakumar |
VPandya General Sponsor
Posted: Sun Dec 11, 2016 5:27 pm Post subject: In USA we give a Drawing with Foundation Reactions to Geotech. |
Dear Er. Rajesh suraypally,
In USA general practice is that a Licensed ( Experience) GEOTECH ( Soil Consultant ) gives TYPE FOUNDATION ( FOOTINGS, RAFT , CAISSONS, PILES ) for the project. All we ( Structural Engineers) give Geotech Consultantant a full size Drawings showing Colum Locations, Shear Wall Locations and a Big Table with Maximum FOUNDATION REACTIONS ( DL, LL, WIND XYZ , EQ-XYZ ) under each Column and each Shear Wall. Based on the Foundation Reactions we give , Geotech calculates TOTAL SETTLEMENTS, DIFFRENTIAL SETTLEMENTS against allowables in the Building Codes. Then he recommends in his final Soil Report a type of Foundation meeting the Code Requirements. Type of Foundation to be used for the project comes from Geotech or Soil Consultant.
I have worked is US for 35 years and except calculating the Maximum FOUNDATION REACTIONS, I have never worried about Type Of Foundation to be used on the project. That is a Geotech. ( Soil Consultant ) specialty.
The reason is Liability ( Legal ) issue . A Licensed Geotech. ( Soil Consultant ) Engr. is fully responsible for a FOUNDATION FAILURE like SAN FRANCISCO, CA 58 story Millennium Tower. See the recent posts on that 58 story tower Foundation Failure.
Vasudeo Pandya P.E.
Structural Engineer |
Posted: Mon Dec 12, 2016 12:34 pm Post subject: |
Vasudeo Pandya P.E. sir
and
E S Jayakumar sir.
thanks for your reply can i get detailed information on design of piles and pile caps....? manual calculation as well as any software...
syed_A ...
Posted: Mon Dec 12, 2016 6:07 pm Post subject: |
Dear Vasudeo Pandya Sir
Thanks for this info....the responsibility of Str engineer and Geotech consultant
in arriving suitable type of foundation
Best regards |
saikiran gone General Sponsor
Posted: Tue Dec 13, 2016 6:54 am Post subject: Re: which type of foundation should recommend for SBC of 5t/m2 clay soils....? |
rajeshsuraypally wrote: | sir,
Hi Rajesh,
As told by Jayakumar sir, it completely depends on the type of soil and structure you are supporting.Please what of structure is construction on this type of soil
If the loads are more you can go for pile foundation. For taller structures pile with raft as a pile cap.
With Best,
Saikiarn. |
Posted: Tue Dec 13, 2016 8:48 am Post subject: |
Hello Sir,
The type of structure is fully commercial complex cellar + 5 upper floors with 51 columns length of structure is 65m and width of structure is 13m. sbc 5t/m2. wind speed 50m/s, and zone-III.
thanks. |
Posted: Wed Dec 14, 2016 2:48 am Post subject: |
Please furnish the details of the Soil Investigation Report.
E S Jayakumar |
