designerstr92 SEFI Member
Posted: Sat Apr 15, 2017 4:26 pm Post subject: how to reduce torsional irregularity |
Respected members ,please tell me is there any procedure to reduce torsional irregularity in plan irregular building without adding shear wall or any other dual system ....if any please tell me the procedure |
naveennunna SEFI Member
Posted: Mon Apr 17, 2017 4:49 am Post subject: |
Dear Member, Please give the L-shapped Columns at the corners and it will help you a lot in removing the torsion in the building |
Posted: Tue Apr 18, 2017 1:55 pm Post subject: |
thankyou sir |
shubham.baheti SEFI Member
Posted: Fri Mar 29, 2019 6:24 pm Post subject: Re: how to reduce torsional irregularity |
designerstr92 wrote: | Respected members ,please tell me is there any procedure to reduce torsional irregularity in plan irregular building without adding shear wall or any other dual system ....if any please tell me the procedure |
Try to find center of mass and center of stiffness, and bring them closer by increasing column size(stiffness)... Also try changing the orientation of columns which are being most deflected. |
patoliyanirav@gmail.com SEFI Member
Posted: Wed May 29, 2019 4:55 am Post subject: |
you have to calculate the Center of Mass and center of Stiffness at floor level and try to minimized the distance between them by providing stiff column or reducing the mass of building. |
