Staad Select 6 series Vs Select 4 series
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Evaluate my Model
Sourabh_Agarwal
PostPosted: Wed May 10, 2017 2:20 am    Post subject: Staad Select 6 series Vs Select 4 series Reply with quote
Hi,
I analysed a PEB structure in both Staad Select 4 Series and Staad Select 6 Series. Results vary a lot. I have attached following in the zip.
1) screen shot of unity check in Staad Select 4 Series
2) screen shot of unity check in Staad Select 6 Series
3) Original Staad File
Can someone please help me understand the reason for the difference?
Sourabh_Agarwal
PostPosted: Sun May 14, 2017 1:08 pm    Post subject: Reply with quote
175 views and still no reply. Can someone please help.
Sourabh_Agarwal
PostPosted: Sat Jun 03, 2017 3:33 am    Post subject: Reply with quote
Can someone please help!!!
rajancivildesign@gmail.co
PostPosted: Wed Jun 07, 2017 2:09 am    Post subject: Result variation between Staad Pro Select series 4 and Select series 6 Reply with quote
Dear Safian,
I have not gone through fully about your attachement and Staad Pro problem. In Select series you have licence fr certain code and in select series 6 you shall be given licence for certain code. Kindly verify the licence whether you done the problem related to same code and licence is available for particular code. If it is OK, then there will be mistake in Select series 4 and 6. Please verify this fist.
Thank you.
V.M.Rajan.
jayesh.shinde
PostPosted: Fri Aug 04, 2017 10:04 am    Post subject: Staad Select 6 series Vs Select 4 series Reply with quote
Check and compare analysis output of axial forces (generated by applyingmember loads on beam sections) in both staad versions. You can understand thereason for difference in strength design check for combined P-M interaction of beams. <o></o>
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Evaluate my Model All times are GMT
