USE OF BAMBOO IN REPLACMENT OF REINFORCEMNT
Noor ul haq
PostPosted: Sat Sep 23, 2017 5:28 am    Post subject: USE OF BAMBOO IN REPLACMENT OF REINFORCEMNT Reply with quote
Hello Sefians
I have found something interesting , which could be an emerging change in the field of construction industry .
please find the link below
https://theconstructor.org/structural-engg/bamboo-reinforced-concrete-mix-design-construction/15054/?utm_source=pushengage&utm_medium=push_notification&utm_campaign=pushengage
Need Expert advice on this .
spsvasan
PostPosted: Thu Oct 19, 2017 4:24 am    Post subject: Re: USE OF BAMBOO IN REPLACMENT OF REINFORCEMNT Reply with quote
Noor ul haq wrote:
Hello Sefians
Dear Er.Noor ul Haq
I am not an expert in bamboo reinforced concrete.
I believe CBRI constructed an experimental bamboo reinforced slab in the early sixties.
While bamboo reinforced concrete is technically feasible, it should be noted that bamboo strength varies from species to species.
Even in the same species, the age at which bamboo was cut influences the strength.
Even within the same age, the season in which bamboo is cut also affects strength
In addition, the durability of a bamboo reinforced structural element depends upon the efficacy of waterproofing treatment given to the bamboo strip reinforcement
Hence, I believe, much more experimental investigations are required before bamboo reinforced concrete can be adopted in the field
S.P.Srinivasan
spsvasan
PostPosted: Fri Oct 20, 2017 4:14 am    Post subject: Reply with quote
Dear Er.Noor ul Haq
I observed that BIS has issued document CED 13 for comments.
This document deals with bamboo as a structural material and includes clauses on bamboo as reinforcement for concrete
Hence an IS code can be expected soon [?]
S.P.Srinivasan
B.V.Harsoda
PostPosted: Sat Oct 21, 2017 6:07 am    Post subject: Reply with quote
I have already listed Draft for Comment at Below link:
https://www.sefindia.org/forum/viewtopic.php?t=6604&postdays=0&postorder=asc&start=620
BIS Draft for comments:
Structural Design using Bamboo - Code of Practice (First Revision of IS 15912) ICS 91.080.20
http://www.bis.org.in/sf/ced/CED13(11987)_15092017.pdf
