hiren_patel SEFI Member
Posted: Fri Dec 22, 2017 6:54 am Post subject: Rectangular water tank with square opening |
Can one design rectangular water tank wall with square opening loaded only by hydrostatic pressure as in same manner as slab with opening?? |
Thankful People |
srinivasa rao palla(25-12, 16:08), Thanks hiren_patel for his/her post
abhio ...
Posted: Mon Dec 25, 2017 3:23 pm Post subject: Re: Rectangular water tank with square opening |
Dear Er Patel,
Water tank walls are subject to direct tension as well as bending. The opening will disturb the flow of force in the tank wall, which will have to be accounted for in your reinforcement detailing.
Also, in case if the opening is provided with some closer (such as a removable entry hatch), then this hatch will have to be designed for the hydrostatic load upon it, and the connection of the hatch to the wall will have to be detailed to transfer the load to the wall. |
Posted: Tue Dec 26, 2017 1:04 am Post subject: Re: Rectangular water tank with square opening |
hiren_patel wrote: | Can one design rectangular water tank wall with square opening loaded only by hydrostatic pressure as in same manner as slab with opening?? |
Dear Er Hiren,
Yes you can do if it is a small opening. But note that the water will escape even if there is a small opening. Hence proper arrangements have to be done. The lid also has to be designed for the hydro-static pressure.
NS |
