Do you agree that requirement of P-delta analysis should be deleted from code? |
Yes |
0% |
[ 0 ] |
No |
100% |
[ 5 ] |
Can't say |
0% |
[ 0 ] |
Total Votes : 5 |
bjgupta SEFI Member
Posted: Fri Mar 16, 2018 1:47 pm Post subject: P-delta analysis |
I have following reservations on clause 7.2.d which requires P-delta analysis.
I don't think software are available to incorporate P-delta effects in dynamic analysis for seismic loads.
Even if software is made available, P-Delta analysis would require design time history of ground displacement or acceleration as input.
There are no guidelines in code to generate above referred input.
Even if both software and design time history is made available, a reliable p-delta analysis would require modelling of material nonlinearity.
As on date I don't think it is practically possible to incorporate material nonlinearity into analysis.
I suggest that requirement of P-delta analysis should be removed from code. |
gautam chattopadhyay ...
Posted: Mon Mar 19, 2018 7:25 am Post subject: P-delta analysis |
synthetic hystogram of earthquakes are available for input as forcing function in dynamic analysis. SAP 4 had provisioion for such analysis and I feel STAAD has also incorporated the algorythm.
Thanks and regards
Gautam chatterjee
On Fri, Mar 16, 2018 at 7:17 PM, bjgupta <forum@sefindia.org (forum@sefindia.org)> wrote:
Quote: | I have following reservations on clause 7.2.d which requires P-delta analysis.
bjgupta SEFI Member
Posted: Tue Mar 20, 2018 2:04 am Post subject: |
Thanks Chattopadyayji for informing. Would like to know whether referred histograms are consistent with requirements of IS 1893 and available for all the zones i.e II to V.
With regards,
(B. J. Gupta) |
