y do we release the member in staad pro.. where should
maheswaran
PostPosted: Thu Aug 25, 2011 8:50 am    Post subject: y do we release the member in staad pro.. where should Reply with quote
y do we release the member in staad pro.. where should v release the member start and end of the member..??
please guide me sir,,,
biswajit.halder
PostPosted: Fri Mar 01, 2013 6:32 am    Post subject: Reply with quote
Generally we release members wherever there is absence of sufficient moment transfer and the connection is not fixed or rigid.
a121s
PostPosted: Mon Mar 04, 2013 9:49 am    Post subject: Member release Reply with quote
I presume that you have a member between A and B, another member between C and D, and a 3rd member between B and D. By cantilevers, you are refering to the first and second members. Am I right?
If the 3rd member is merely resting on the first and second, and not attached through a proper moment connection in the case of steel, or a monolithic construction in the case of concrete, then you need to release MY and MZ on the first and second members. But MX should be released in one of those two only. Releasing MX on both of them will make the 3rd member torsionally unstable.
Alternatively, you can release MX, MY and MZ at node B of member 3, and MY and MZ at node D of member 3. In this case, you won't release anything in the first and third members.
SHISHIR S. KADAM
M.Tech(Structures),A.M.I.E
Vijay Solanki
PostPosted: Thu Sep 22, 2016 7:26 am    Post subject: A video showing how to release moments in beams in staad pro Reply with quote
Dear,
As you got the answer for why do we release moments in staad pro, here is a link showing how to release moments in beams in staad pro.
https://youtu.be/UcbelletS18
saikiran gone
PostPosted: Thu Sep 22, 2016 9:24 am    Post subject: Re: y do we release the member in staad pro.. where should Reply with quote
Hi Maheswaran,
Q. y do we release the member in staad pro
To make the pinned connection we release the moments in the member.
It depends on the engineer if he wants to make the beam simply supported (i.e want to transfer only vertical force not the moment, especially in secondary beams ) he can release the moments in staad.pro at both ends (start and end ).
If he wants to release the moment only at one end , he should define either Start or End release  specification and assign to the beam at the required end.
With Best,
Saikiran.
