Is Epoxy coating practical of TMT bars practical?
vbetty080
PostPosted: Mon Dec 10, 2018 5:08 am    Post subject: Is Epoxy coating practical of TMT bars practical? Reply with quote
Is Fusion-Based Epoxy coating a practical means to prevent corrosion in TMT steel bars.
Aneesh_Surjith
PostPosted: Sat Dec 29, 2018 6:16 am    Post subject: It is expensive and needs professionals Reply with quote
Fusion Bonded Epoxy (FPE) coating is a process where the epoxy powder is applied by electrostatic spray on hot steel at a pre-set temperature level. This is an irreversible process and provides the protection to reinforced steel bar against corrosion. It prevents the attack of chloride ion on the metallic surface and occurrence of electrochemical reaction initiating the corrosion of steel. Due to these advantages, we can say that the FPE coating is a practical means to prevent corrosion, however, there are restraining factors such as the high costs associated with the coating process. The lack of skilful handling to avoid the peeling of the coating during the cutting, bending process is another factor.
