rajancivildesign@gmail.co ...
Posted: Thu Jun 16, 2016 3:31 pm Post subject: Earthquake analysis as per IS1893 using staad pro |
Dear E.S.Jayakumar Sir,
As requested the Earthquake Analysis Procedure for static method with reference to IS 1893 along with Staad pro example is attached for reference and benefit of fresh Engineers.
V.M.RAJAN.
Member weight method .pdf |
218.05 KB |
1092 Time(s) |
lumped mass method example .pdf |
67.15 KB |
1921 Time(s) |
seismic analysis Lumped Mass procedure.pdf |
2.11 MB |
2091 Time(s) |
Earthquake Analysis procedure .pdf |
39.37 KB |
6919 Time(s) |
Thankful People |
shankar_sanni(25-06, 9:54), Thanks rajancivildesign@gmail.co for his/her post
Posted: Fri Jun 17, 2016 2:51 pm Post subject: Dynamic Analysis-Response Spectrum Method |
Dear SAFIAN,
In continuation to Static method, I herewith attached the Dynamic Analysis-Response Spectrum Method for reference to fresh engineers. If any comments on method on earth quake analysis, expert opinion is invited.
V.M.RAJAN.
Dynamic-Response.pdf |
266.54 KB |
2218 Time(s) |
es_jayakumar General Sponsor
Posted: Sat Jun 18, 2016 5:44 am Post subject: |
Thank you, Rajan Sir. Your contributions to this forum are really commendable.......
Posted: Sun Jun 19, 2016 7:50 am Post subject: Earthquake analysis as per IS1893 using staad pro |
Dear Jayakumar sir,
Thank you for your reply. Here I want to mention one errata in my posting. The size of building for lumped mass and member weight method as per sketch is 15m x 15m. But in my text it is mentioned as 12mx12m. Kindly corect the size and and read it. In geometry step also length along X and Z is 15m with 5 bays with each bay 3m. If somebody master in Staad pro use different method, kindly indicate the procedure if they want to mention. If anybody wants other procedure on time history, mode shape, natural frequency on rayleigh and eighen value extraction method, I shall post it in this forum for reference. Thank you for the interest shown by members.
V.M.RAJAN.
Posted: Sun Jun 19, 2016 3:32 pm Post subject: Time History Method |
Dear SAFIAN,
In continuation to dynamic earthquake analysis, Time History method is attached for reference to our members.
V.M.RAJAN
EQ DATA.rar |
189 Bytes |
755 Time(s) |
Time History method.pdf |
201.23 KB |
2313 Time(s) |
aditya ...
Posted: Mon Jun 20, 2016 5:07 pm Post subject: |
Dear Rajan Sir,
Thanks a lot for uploading the examples which are really very usefull to all of us.
Can you explain the use of IMB, IPLM and PLASTIC commands to be used while using IS 13920 design in Staad.Pro? Can you give specific example citing when to use or not to use these commands?
with best regards,
Aditya
Posted: Tue Jun 21, 2016 4:58 am Post subject: Earthquake analysis as per IS1893 using staad pro |
Dear Aditya,
I am not expert in staad pro. I request our senior engineers like Pandiya sir or others who are well experienced in staad pro can reply for this. still I am in learning stage only. Thank you,
V.M.RAJAN.
aditya ...
Posted: Wed Jun 22, 2016 1:16 am Post subject: |
Dear Sukant Adhikari Sir, Arun Kumar Sir and other fellow Sefians,
May I request for your help in this regard?
with best regards to all,
Aditya
Posted: Wed Jun 22, 2016 1:40 pm Post subject: Earthquake analysis as per IS1893 using staad pro |
Dear SAFIAN,
To conclude this topic on earthquake analysis,
I herewith attached the method for calculating frequency on RCC Building
for the use of fresh engineers.
V.M.RAJAN.
Eigen value Extraction method-.pdf |
89.6 KB |
1051 Time(s) |
Rayleigh Freqency method.pdf |
55.44 KB |
1025 Time(s) |
ganesh_gaud General Sponsor
Posted: Thu Jun 23, 2016 10:14 am Post subject: |
very useful work by rajan sir, thanks for posting.
Ganesh
