Is it recommendable to propose a Box Culvert in two Vetical Steps to economise the side wall by reducing its height?
kawalbhatia
PostPosted: Fri May 03, 2019 7:03 am    Post subject: Is it recommendable to propose a Box Culvert in two Vetical Steps to economise the side wall by reducing its height? Reply with quote
Can we propose a Box Culvert in two vertical steps so as to economise the vertical wall of about 7 m total height by reducing its height to half?
Need your valuable suggestions.
Thanks.
Kawal Bhatia
ME Structures
Photograph of an existing Box type Structure
 Filesize:  233.1 KB
 Viewed:  57 Time(s)
naresh24
PostPosted: Sat May 04, 2019 5:00 am    Post subject: Re: Is it recommendable to propose a Box Culvert in two Vetical Steps to economise the side wall by reducing its height? Reply with quote
Dear Kawal,
Certainly One can design two step wall but the Disadvantage of casting is inducing horizontal construction joints in walls which are prone to leakages, but you can certainly reduce reinforcement as required along the length of wall.
Best Regards,
Naresh sanghavi
Thanks.
Kawal Bhatia
ME Structures
abhio
PostPosted: Sat May 04, 2019 7:07 am    Post subject: Reply with quote
Looks good to me. You could reduce the material requirement by using beams instead of a slab to break the height of the walls.
