Moment distribution for continuous beams with diaphragms
Goto page 1, 2  Next
Arpansk
PostPosted: Sun Aug 25, 2013 2:16 am    Post subject: Moment distribution for continuous beams with diaphragms Reply with quote
Hello,
I am very new to this forum, just joined recently.
I have a query regarding moment distribution for beams with variable stiffness. I am carrying out a line beam assessment on a continuous slab and beam deck with 4 spans. E is constant in this case, however, I changes at support regions due to the diaphragms at supports. Can anyone please explain how the moment distribution happens. Since the beam is much stiffer at support regions, how can I proportion the moment transferred to the beam section at diaphragm and beam section with no diaphragm.
Looking forward to your valueable advise.
Arpan
Rajesh123
PostPosted: Mon Aug 26, 2013 9:35 am    Post subject: Reply with quote
My suggestion for you is to study 'Hardy Cross analysis of Moment distribution' from any book on "Structural Analysis".
rajancivildesign@gmail.co
PostPosted: Wed Aug 28, 2013 2:49 am    Post subject: Moment distribution method by Hardy cross method Reply with quote
An example showing moment distribution method for portal frame is attached for reference.
V.M.RAJAN
Portal-GS.pdf
 Filename:  Portal-GS.pdf
 Filesize:  436.16 KB
 Downloaded:  2073 Time(s)
B.V.Harsoda
PostPosted: Thu Aug 29, 2013 11:09 am    Post subject: Reply with quote
A Spreadsheet for moment distribution method  is attached for reference.
Moment Distribution.XLS
 Filename:  Moment Distribution.XLS
 Filesize:  88 KB
 Downloaded:  1613 Time(s)
syed_A
PostPosted: Thu Aug 29, 2013 4:44 pm    Post subject: Reply with quote
hello all
more spreadsheets can be found here for ref
http://www.sefindia.org/forum/viewtopic.php?t=9832&postdays=0&postorder=asc&start=0
PostPosted: Fri Aug 30, 2013 1:01 am    Post subject: Spread sheet in Excell Reply with quote
All sheets available in Excell format  are useful. But not even one sheet found for Indian code. What is the use in applying to our design in India.
V.M.RAJAN
B.V.Harsoda
PostPosted: Sat Aug 31, 2013 3:11 am    Post subject: Re: Spread sheet in Excell Reply with quote
Use depend upon personal level of vision and also personal level of knowledge. Keep in mind that this forum is not limited for Indian codes users only. What is role of code in analyses method in listed analyses spreadsheets ?
V.M.RAJAN
Madghumathi.H.G
PostPosted: Thu Sep 12, 2013 12:16 pm    Post subject: Moment distribution for continuous beams with diaphragms Reply with quote
Good Evening Mam/Sir
I wanted to Learn the Flat Slab Design So i am Requesting  to Send me related pdf files with Drawing or youtube Lecturing.
Thank You        yours faithfully
        (MADHUMATHI.H.G)
On Sun, Aug 25, 2013 at 7:46 AM, Arpansk <forum@sefindia.org (forum@sefindia.org)> wrote:
           Hello,
Arpan
B.V.Harsoda
PostPosted: Sat Sep 14, 2013 5:58 am    Post subject: Reply with quote
Masterseries Flat Slab Design
B.V.Harsoda
PostPosted: Sat Sep 14, 2013 6:20 am    Post subject: Reply with quote
Goto page 1, 2  Next
Page 1 of 2
