Expansion joint in steel roof
MMuraliCEG
PostPosted: Sat Jun 01, 2019 4:36 am    Post subject: Expansion joint in steel roof Reply with quote
Hi Sefians!
I have a case,
I'm designing a steel roof structure of 165m. braced bays are provided.
As per IS 800-2007, if we are going multiple braces we shall go
upto 230m without any expansion joint.
hence I'm satisfying that case. My query case the below three concrete
floors is having expansion joint at 90m and construction also will be two
stages. Is it necessary to follow the expansion joints as provided in the
concrete floors.
Please advise.
Murali
spsvasan
PostPosted: Sat Jun 08, 2019 3:19 am    Post subject: Re: Expansion joint in steel roof Reply with quote
MMuraliCEG wrote:
Hi Sefians!
I have a case,
concrete floors.
Please advise.
Murali
Dear Er.Murali
The width of the expansion joint in the building below will vary with the seasons. Hence I feel that it is better to continue with the expansion joint in the steel structure also
S.P.Srinivasan
mandeep_singh_kohli
PostPosted: Tue Jun 11, 2019 12:18 pm    Post subject: Re: Expansion joint in steel roof Reply with quote
Can you show a Figure ?
How many Brace bays do you have in one direction, if you only have a single bay at the center, then you dont need expansion joint.
If you have multiple braced bays at some distance apart, then it will be the brace bays location which will be the deciding factor, Keep them independent. Your load should transfer to one braced bay and the next braced bay should be a slotted connection to the first so as to keep the load path short and simple. i.e if you have braced  bys after every 60mt, then you need a slotted connection after every 60mt. So that the load for first 60mt flows to first braced bay, second to second and so forth.
MMuraliCEG wrote:
Hi Sefians!
I have a case,
concrete floors.
Please advise.
Murali
