P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000
BivekSigdel
PostPosted: Thu Aug 15, 2019 2:21 am    Post subject: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
Dear all,
I've searched a lot, but still couldn't get an idea what is the appropriate loading case or combination to get the values of P and V while defining auto hinge for pushover analysis in etabs or sap2000.  P and V values are required as per the table 10-7, 10-8 of ASCE 41-13, table 6-7, 6-8 of FEMA 356 and table 11-3, 11-4 of ATC 40.
For each column the P value can be maximum due to different load combinations. So does it mean that I have to know which combination gives max. P in each column and assign different auto hinge for each column? Also the case/combination for maximum value of V can be different from P. In this case how can we assign only one load case/combination for both P and V values.
For beams, maximum V values result from the ductility requirements due to sway and hinge formation in beams and not from load cases/combinations.
I would really be grateful if somebody could give me an insight to which load case/combination is appropriate of P and V values while defining auto hinge for pushover analysis in etabs or sap2000.
Please see the picture attached.
Thankyou,
 Filesize:  25.72 KB
 Viewed:  333 Time(s)
rojanmathewtsy
PostPosted: Fri Aug 16, 2019 6:50 am    Post subject: Re: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
BivekSigdel wrote:
Dear all,
Thankyou,
Regarding your query on the P value,
M3 hinge(Moment-curveture relationship) will be varying depending on the axiall load acting on the cross section. Since the axial load varies on different load case, your M3 curve will also vary depending on the load case.
So basically you will be doing pushover after the end of one specific load case that you will be mentioning while defining the pushover load case(in the initial stiffness condition box) . So here , you have to mention that load case that you used to define the pushover.
So if you are planning to check pushover with respect to different load cases, then you may have to make different models to check that.
Regarding V value also, you can follow the same load case. You can manually input the shear reinforcement ratio as your shear design is governed by ductile requirement.
Note- Columns will be governed by PMM hinges as it will be having combined action of axial load and bi axial moments.
Rojan Mathew
mathew.rojan@gmail.com
BivekSigdel
PostPosted: Sun Aug 18, 2019 3:15 am    Post subject: Re: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
[quote="rojanmathewtsy"]
"So here , you have to mention that load case that you used to define the pushover. "
Thankyou for your response,
Suppose for initial stiffness I create a load case i.e NLDEAD
Then following the NLDEAD load case I define Load cases Push-X and Push-Y.
Now for P and V values do you mean I should take the values from NLDEAD or Push-X and Push-Y ?
rojanmathewtsy
PostPosted: Tue Aug 20, 2019 4:25 am    Post subject: Re: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
[quote="BivekSigdel"]
If you are doing push x and Push Y , then you have to consider two models, Model 1 for push X where P and V value will be of Push X and Model 2 with push Y.
But I will recommend you to go for manual hinges that you can define using section designer.
1.For Columns-
  Define PMM hinges - that will not be load case depend-it will be constant for a section. So you dont have to make different Models.
  Define Shear Hinges also- Shear hinge will be also depend on your section property only.
2. For Beams
   Define M2 or M3 hinges -Here the Moment hinges will be constant with respect to the cross section as axial load P is Zero or negligible in beams.
   Define  Shear hinges also.
Rojan Mathew
BivekSigdel
PostPosted: Fri Aug 23, 2019 1:17 am    Post subject: Re: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
1.For Columns-
2. For Beams
Rojan Mathew
Thankyou Mr. Rojan, however since Pushx and PushY are two seperate load cases, SAP or ETABS can seperately analyse both cases. So is it still necessary to work on two seperate models?
rojanmathewtsy
PostPosted: Sun Aug 25, 2019 3:30 pm    Post subject: Re: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
1.For Columns-
2. For Beams
Rojan Mathew
They can do different analysis but here you will be having different hinges with respect to the specific load case you are analysing. That is one column will be having a hinge with axial load with respect to push X and another hinge with push y. So you have to do two model
Model 1 for pushx- where column 1 will have hinge with respect to push X.
Model 2 will have hinge with respect to push y.
BivekSigdel
PostPosted: Sun Aug 25, 2019 4:43 pm    Post subject: Reply with quote
Thankyou Mr. Rojan. I'll do a case analysis about what you said.
