A B Malla General Sponsor
Posted: Mon Sep 16, 2019 8:56 am Post subject: shear stress in bolts |
I would like to know the difference in Permissible Stresses of Bolts considered in Table 8.1 of IS:800-1984 & Table 1 of IS 802 ( Part l/Set 2 ) : 1992, since both these tables show different values. kindly share your expertise.
PFA Tables for reference.
A. B Malla |
Joined: 21 Feb 2008 Posts: 5553 Location: Gaithersburg, MD, U.S.A.
Posted: Tue Sep 17, 2019 3:56 am Post subject: Re: shear stress in bolts |
Dear Er Malla
IS 800:1984 is in Working stress format(we have to now use IS 800:2007 only) and IS 802 table shows ultimate stress. Hence the difference. It is better now to use the values given in IS 800:2007
Abrar wrote: | Dear Sefians,
A. B Malla |
Posted: Tue Sep 17, 2019 4:47 am Post subject: |
Dear sir,
it is as per contract requirement to use IS 800 :1984, since the project is old & is still going.
1. IS 802:1992, it is observed permissible shear stress in 4.6 grade bolts is 218 Mpa, while for same grade of bolt permissible stress is 80 Mpa in IS 800:1984.
2. I presume both IS 800 & 802 are working stress please clarify.
3. while designing bolts for tower, which stress is to be considered.
(In Transmission line structures by S.S Muthy & A.R Santhakumar, IS:800:1984 table is mentioned).
i'm delighted to see the reply is coming from author of the book, which i was referring to in my UG & PG . Thanks to SEFI.
Regards A.B Malla |
Posted: Wed Sep 18, 2019 6:52 pm Post subject: |
Dear Er Malla,
Please note that while IS 800:1984 is based on working stress method, IS 802: 1995 is based on Ultimate load concept- See Back of Front Cover of IS 802(Part 1/Sec 1): 1995. Hence there should not be any confusion, though it is not stated clearly in IS 802(Part 1/Sec 2) of the code.
Perhaps this code (IS 802) will also be revised based on IS 800:2007 soon.
Good to know that you referred my book in UG and PG. All the best.
A B Malla wrote: | Dear sir,
Regards A.B Malla |
Posted: Sat Sep 21, 2019 4:21 am Post subject: shear stress in bolts |
Dear N S Sir,
Thank you very much for your valuable time from your busy schedule. Such efforts from your side benefits all of us.
A B Malla |
