Planets+Earth Dynamism
suraj
PostPosted: Sun Nov 17, 2019 1:02 pm    Post subject: Planets+Earth Dynamism Reply with quote
We have to know many parameters about nature/universe
Table gives certain plenetry motions for awareness & realisation about, how dynamic equilibrium has been working since solar system was installed & commissioned
Information about size of planets & other information collected from reliable sources
Solar System.xlsx
 Filename:  Solar System.xlsx
 Filesize:  13 KB
 Downloaded:  119 Time(s)
suraj
PostPosted: Mon Nov 18, 2019 1:01 pm    Post subject: Planets+Earth Dynamism Reply with quote
Revised & Updated
Sun parameters added
Solar System.xlsx
 Filesize:  13.93 KB
 Downloaded:  103 Time(s)
suraj
PostPosted: Tue Nov 19, 2019 10:40 am    Post subject: Solar System Dynamism Reply with quote
Above table gives certain information, pertinent Solar System, based on various references used from web
Solar system comprising of various planets is working in dynamic equilibrium
All planets are revolving around their repective axes, continuously
Planets other than Sun are also, revolving around Sun with defined velocities/speeds
How many days does one planet consume to move around at its axis are indicated
How many days does one planet consume to move around Sun are indicated
Diameter & Volume  of each planet is indicated
Each planet own rotating speed & speed around Sun (Orbital speed) are indicated
Propulsion force produced by each planet, except Sun, because of Orbital movement is indicated
Respective Centrifugal Forces are also, indicated
Parameters respecting Sun are indicated seperately, because Sun does not rotate around itself, but only on its axis
Earth rotates on its axis @ 1636 KM/HR & Around Sun @ 108088 KM/HR
Escape Velocity of Sun is 2223720 KM/HR, means there exists no planet that can face Sun's self revolving Velocity
Diameter of Sun is 13.91 Million KM, whereas, Earth is only 12500 KM in Diameter
Amazingly, Sun's Internal Propulsion Force is enormously Number of Times of other Planets' Propulsion Force
This Number varies from minimum 47 to maximum 78581 for Jupiter & Mars respectively
For Earth, it is only 3631
Earth is moving around Sun @ 108088 or more, which is highest planetary speed around Sun among all other planets
If, some missile or racket attacks surface of Earth from space, Earth could be Jeopardised very badly
If, some racket is launched from Earth for a trajectory to enter space & then commanded to return to Earth to attack it,
Earth can be endangered & its existence can be challenged by some devils minds
No vehicle could be designed & built to reach to Sun & even, if it reaches Sun,
it does not look feasible to have a speed of say 2.5Million/Hour, When it reaches
Illumination power at Sun is 38300000000000000000000000 Watts, which is impossible to be digested
Earth produces Propulsion Force 60900000000000000000000000 TKM/Hour, Highest among all Planets, except Sun
Solar System.xlsx
 Filesize:  16.67 KB
 Downloaded:  100 Time(s)
suraj
PostPosted: Wed Nov 20, 2019 5:03 am    Post subject: Solar System Dynamism Reply with quote
Talk-1
https://www.facebook.com/pesuraj/videos/3127028043980012/
suraj
PostPosted: Fri Nov 22, 2019 1:21 pm    Post subject: Solar System Dynamism-22.11.2019-Update-Skecth Reply with quote
Solar
https://www.scribd.com/document/436340616/SolarSystemDynamism-1
https://www.scribd.com/document/436189521/SolarSystem-DynamicDetails-21-11-2019
SolarSystem-DynamicDetails-21.11.2019.xlsx
Worksheet
 Filename:  SolarSystem-DynamicDetails-21.11.2019.xlsx
 Filesize:  20.97 KB
 Downloaded:  124 Time(s)
SolarSystemDynamism-1.pdf
Sketch
 Filename:  SolarSystemDynamism-1.pdf
 Filesize:  120.12 KB
 Downloaded:  88 Time(s)
suraj
PostPosted: Fri Nov 29, 2019 6:15 am    Post subject: Planets+Earth Dynamism Reply with quote
UpdateUniverse-Solar System-Dynamic Working-Planets-Parameters-English-Hindi-3-29.11.2019https://www.facebook.com/pesuraj/videos/3150305918318891/
