Plinth Beam Depth
ramu_se
PostPosted: Mon Jan 20, 2020 5:28 pm    Post subject: Plinth Beam Depth Reply with quote
Hi All,
If the distance between center to center of the column is 22" in plinth beam layout,there is a wall load coming on 1/4 of the beam each side.
In this case,is it sufficient to provide the plinth beam depth as 15"?? instead of 24"
Please find the attached image for reference.
Thanks.
Ramu.
 Filesize:  8.47 KB
 Viewed:  25 Time(s)
thirumalaichettiar
PostPosted: Sat Feb 08, 2020 3:06 pm    Post subject: Reply with quote
Er.Ramu,
U have wrongly typed 22" instead of 22'. U Need to provide a stub column or an intermediate support to reduce the depth to 15". If u use 22' span u need at least a depth of (satisfying the deflection) the span/depth ration as given in the code.
