Failure of overhead water tank,at BANKURA,WEST BENGAL
Goto page 1, 2, 3, 4  Next
uhvaryani
PostPosted: Thu Jan 23, 2020 7:30 am    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
Dear Sefians,   Recently,a failure of an overhead water tank,supported on a reinforced concrete shaft of 150 mm thickness and of height 7.5 m has been reported in the media.
The shaft broke at about mid-height.What could be the reason of this failure?
Earlier cases of failure of these structures showed sinking of the shaft in the ground.In the present case soil is reported to be good, so the shaft has broken into two parts.I request our senior members to consider this case and give us the reason of this failure.My view is that the shaft thickness of 150mm is in sufficient and this has caused local buckling of the shaft.
with best wishes and regards,
uhvaryani
RAMARAJ S
PostPosted: Thu Jan 23, 2020 9:30 am    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
Dear Uhvaryani, What is the condition of Tank, I mean fully filled or partially or empty? What is the dimension of Tank? If  you have any structural drawing, Kindly produce for analysis
On Thu, 23 Jan 2020 at 14:28, uhvaryani <forum@sefindia.org (forum@sefindia.org)> wrote:
uhvaryani
vivek_agrawal
PostPosted: Thu Jan 23, 2020 9:50 am    Post subject: Reply with quote
it seams, lap length / curtailment of reinforcement / staggering of lap failure which resulted in buckling failure
sangeeta_wij
PostPosted: Thu Jan 23, 2020 10:30 am    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
Yes, local buckling could be a reason, and it will be helpful to know the diameter of the shaft as well as the size/shape of the top .In any case, 1893 Code for Tank design has changed quite drastically, and it will be nice to carry out a check of all existing elevated staging tanks based on that.
Best Regards
Sangeeta Wij
President,WISE India
Managing Partner
SD Engineering Consultants LLP
Vice President(North),Indian Association of Structural Engineers,
Fellow and Chartered Engineer, Institution of Engineers
H333 New Rajinder Nagar(Lower Ground Floor),
New Delhi-110060
Ph:9811776210;01145128530
Sent: 23 January 2020 14:26
Subject: [SEFI] Failure of overhead water tank,at BANKURA,WEST BENGAL
uhvaryani
indutridibesh
PostPosted: Thu Jan 23, 2020 12:30 pm    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
Here is a link to the complete videohttps://youtu.be/vUEhqlBTCqo
The circumferential crack in the shaft is clearly visible from some time ahead of collapse. The crack might be due to inadequate reinforcement and/or weak joint in concrete as well.
If the shaft wall is thin enough in proportion to its diameter, then the wall would wobble and it may fail when there is bending of the shaft.
On Thu, 23 Jan, 2020, 14:27 uhvaryani, <forum@sefindia.org (forum@sefindia.org)> wrote:
uhvaryani
vgrelan
PostPosted: Thu Jan 23, 2020 2:30 pm    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
What was the unsupported length of the shaft?
On Thu, 23 Jan, 2020, 4:26 PM sangeeta_wij, <forum@sefindia.org (forum@sefindia.org)> wrote:
Best Regards
Sangeeta Wij
Managing Partner
New Delhi-110060
From: uhvaryani [mailto:forum@sefindia.org (forum@sefindia.org)]
uhvaryani
janak_436
Sir/mam can you send me please full etabs course in pdf format?
On 23 Jan 2020 6:25 p.m., "sangeeta_wij" <forum@sefindia.org (forum@sefindia.org)> wrote:
Best Regards
Sangeeta Wij
Managing Partner
New Delhi-110060
uhvaryani
aknargotra
PostPosted: Thu Jan 23, 2020 6:30 pm    Post subject: Failure of overhead water tank,at BANKURA,WEST BENGAL Reply with quote
Dear Sefians
Height appears to be much more than 7.5 m. Compare with building height. This was waiting to happen since there was a big circumferential crack. Exact reasons can be analysed once full particulars of structure including history of crack is known.With regards,
Ajay Kumar
On Thu 23 Jan, 2020, 10:56 PM indutridibesh, <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            Here is a link to the complete videohttps://youtu.be/vUEhqlBTCqo
On Thu, 23 Jan, 2020, 14:27 uhvaryani, forum@sefindia.org (forum@sefindia.org))> wrote:
James_Cohen
The video suggests loss of strength at the point of failure. There is no tilting, the failure is circumferential and the collapse is primarily vertical. The mode of failure therefore appears to be crushing or hoop failure. Loss of strength is most likely due to longterm corrosion.
Sent: Thursday, January 23, 2020 12:39 PM
Subject: [SEFI] Re: Failure of overhead water tank,at BANKURA,WEST BENGAL
On Thu, 23 Jan 2020 at 14:28, uhvaryani forum@sefindia.org (forum@sefindia.org))> wrote:
Bijoy Chandra Tripathy
Dear Sefians,It reminds of the failure of OHT in Dhenkanal,Odisha in the early 80s.Among the causes 'bad' concreting and lack and deficient structural details eg lap locations and lap details were said to be the critical ones.Government had not gone for detailed technical investigation.Valuable data got buried.
In the present case the TV footage indicates collapse of the RCC shaft at a particular height /zone.It is quite possible that improper placing and compaction of concrete in the thin section of 150mm(?) coupled with lack of continuous curing both inside and outside might be original culprit!However detailed investigation to the causes of failure must be instituted by WB Government in the national interest.
With regards
Er B C Tripathy
On Thu, 23 Jan 2020, 23:09 RAMARAJ S, <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            Dear Uhvaryani, What is the condition of Tank, I mean fully filled or partially or empty? What is the dimension of Tank? If  you have any structural drawing, Kindly produce for analysis
Page 1 of 4
