Roof treatment by Brick Coba
sspawar
PostPosted: Wed Jul 15, 2020 3:50 am    Post subject: Roof treatment by Brick Coba Reply with quote
Dear Sirs,
We have a 60 m by 10 M BUILDING RCC roof.
Once a layer of 75 mm screed with some market available waterproof product and methodology has been done but it did work and now Brick coba of 100 mm thick is being suggested over screed surface.
Is it work there.
load of coba is not concerned.
Is there any other alternate without breaking the screed layer already laid over RCC slab of average 75 mm thick.
Thanks in advance.
PostPosted: Thu Jul 16, 2020 2:40 am    Post subject: Reply with quote
Do you experience leakage through the existing screed ? Why cannot you try membrane waterproofing such as APP and the like, which will not impose much additional deal load on the roof ? APP item  is incorporated in the CPWD Delhi Schedule of Rates (DSR) also. Of the many brands dealing with APP, the Data Sheet of one brand is enclosed, for guidance.
wp_shield_103_p.pdf
 Filename:  wp_shield_103_p.pdf
 Filesize:  118.35 KB
 Downloaded:  68 Time(s)
suraj
PostPosted: Thu Jul 16, 2020 11:29 am    Post subject: Re: Roof treatment by Brick Coba Reply with quote
How many rainwater outlets/gargoyles have been installed?
What gradient to roofing allowed? It should be 1.5 to 2%
Minimum 50 to 75 mm depending on materials
Why was Foam Concrete not tried?
Use Tapecrete coating in 2 or 3 coats & then overlay with lighter concrete in slope
sspawar wrote:
Dear Sirs,
Is it work there.
Thanks in advance.
sspawar
PostPosted: Fri Jul 17, 2020 5:57 pm    Post subject: Reply with quote
Yaa it was proposed from contractors side but some past experienced seniors have rejected the proposal saying in long term after getting heat the membrane (sheets) get split out from roof surface and form air bubble spaces which cause leakages again.
Can you give some name of works where it majorly used and resulting good in long terms i.e. 5 years or so.
What is your experience , how it behave in summer days.
Thanks and regards
PostPosted: Sun Jul 19, 2020 5:42 am    Post subject: Reply with quote
As per my experience, APP will endure for more than 5 years, if properly laid with quality material. It is possible that high atmospheric temperature may affect its durability thereafter. If the substrate is not enough stiff, and it is likely develop soft pockets here and there, use of such flexible membranes is advisable. Alternatively, waterproofing chemicals can be applied over the substrate, if found stiff, and the same has to be protected with rich cement plaster, to avoid abrasion. In any case, minimum slope to drain off rain water has to be maintained for the treated surface.
Binoy Bhuson Saha
PostPosted: Tue Jul 21, 2020 4:30 pm    Post subject: Roof treatment by Brick Coba Reply with quote
May be try for foam concrete.
