vikram.jeet General Sponsor
Posted: Mon May 10, 2021 9:10 am Post subject: |
Learning from failures by R N Raikar , is a definitely cautionary book.
But I think , The Book - STRUCTURES by Mahender Raj
is learning from success.
This book is penned by three authors , Vandini Mehta , Rohit Raj Mehndiratta , & Ariel Huber .
Posted: Mon May 10, 2021 9:57 am Post subject: |
KHANNA's HANDBOOK
The KHANNA's HANDBOOK has served the Civil Engineering fraternity since , I think , past 50 yes or so. This Handbook was available with most practising Civil & Structural engineers , be it in libraries or as personal reference book.
It was available when many books and HBooks were not there. It was a ready reference covering all disciplines under umbrella of Civil Engineering.
It was also kept at constuction site offices as covers lot of useful information for field engineers.
Posted: Fri Jul 16, 2021 7:53 am Post subject: |
Few IS Codes related to Soil/Foundations
SOIL/FOUNDATIONS
2720 tests on soils (41 parts)
6403 cop for bearing capacity of shallow foundations
8009 cop for calculation of settlement of foundations
pt1-- shallow found. Subjected to sym. Static vertical loading
pt2-- deep found. Subjected to sym. Static vertical loading
1080 COP for Design & construction of shallow foundation in
soils (other than raft and ring found)
13063 structural safety of buildings on shallow foundations on rocks --withdrawn
12070 cop for shallow foundation on rock
2911 cop for design and construction of pile foundation
pt1/sec1 driven cast ni situ concrete piles
pt1/sec2 boredcast ni situ concrete piles
pt1/sec3 driven pre cast concrete piles
pt1/sec4 bored precast concrete piles
pt2 timber piles
pt3 under-reamed piles
pt4 load tests on piles piles
14593 design and construction of bored cast-in-situ piles founded on rocks
5121 safety code for piling and other deep foundations
2950 cop for design and construction of raft foundations
2974 cop for design and construction of machine foundations
pt1 foundation for reciprocating type m/c
pt2 foundation for impact type m/c
pt3 foundation for rotary type (medium & high fequency) m/c
pt4 foundation for rotary type m/c of low frequency
pt5 foundation for impact type m/c other than hammers
(forging & stamping press
13301 guidelines for vibration isolation of machine foundations
3955 COP for design of well foundations (withdrawn)
9456 cop for design and construction of shell foundations
11089 cop for design and construction of ring foundations
4091 cop for design and construction of foundations for transmission
towers and poles
7207 criteria for design of generator foundation for HEP station
4332 methods for tests of stabilized soils (10 parts)
4434 cop for in -situ vane shear test for soils
4968 methods for subsurface sounding for soils (3 parts)
4999 recommendations for grouting of pervious soils
13094 guidelines for selection of ground improvement techniques
for foundations in weak soils
10042--cop for site investigation for foundation in gravel boulder deposits
12208 methods for measurement of earth pressure by hydraulic pressure cell
5050 cop for design construction& maintenance of relief wells
v
Posted: Fri Jul 16, 2021 7:56 am Post subject: |
Dear Engineers
Few codes are listed below.
STEEL STRUCTURES / ALUMINIUM /CAST IRON RELATED
Steel
226 Structural steel (superseded )
2062 Steel for general structural purposes
IS 1730 : Dimensions for steel plates,sheets strips and flats for general engineering purposes
IS 1732 : Dimensions for round and square steel bars for structural and general engineering purposes
800 COP for general construction in steel
IS 801 : 1975 Code of practice for use of cold formed light gauge steel structural members in general
building construction
4923 Hollow steel sections for structural use
1915 Steel Bridges((code withdrawn)) ----- refer IRC 24
1024 Use of Welding in Bridges and structures subjected to Dynamic loads
12843 tolerance for erection of steel structures
7215 Tolerance for fabrication of steel structures
8629 COP for protection of iron&steel structures from atmospheric corrosion
(3parts)
8062 4 parts ---cop for cathodic protection of steel structures
9172 recommended design practice for corrosion prevention of
steel structures
3402 Steel Chequerd plates
2750 Steel scaffoldings
4014(pt1) COP for steel tubular scaffolding -- definition and materials
4014(pt2) COP for steel tubular scaffolding--safety regulations
6521 COP for design of tower cranes
802 COP for use of Structural Steel in OH transmission line towers
Part-1
Sec-1Materials & Loads
Sec-2 Permissible stresses
Part-2 Fabrication,Galvanizing,Inspection,Packing
Part-3 Testing
IS 803 : Code of Practice for Design Fabrication and Erection of Vertical Mild Steel
Cylindrical Welded Oil Storage Tanks
804 Rectangular pressed steel tanks
805 COP for use of Steel in gravity water tanks
806 COP for use of steel tubes in general building construction
IS 808 : Dimensions for Hot Rolled Steel Beam, Column, Channel and Angle Sections
IS 811 : Cold formed light gauge structural steel sections
IS 8081 : Specification for slotted sections
3443 Crane rail sections
3964 Light Rails
3935 COP for composite construction
11384 COP for composite construction in structural steel and concrete
9178 criteria for design of steel bins for storage of bulk materials
IS 9178 : Part 1 : Criteria for design of steel bins for storage of bulk materials Part 1 General requirements and assessment of loads
IS 9178 : Part 2 : Criteria for design of steel bins for storage of bulk material Part 2 Design storage criteria
IS 9178 : Part 3 : Criteria for design of steel bins for storage of bulk materials Part 3 Bins designed for mass flow and funnel flow
6533(pt1) COP for design and construction of steel chimneys--mechanical aspects
6533(pt2) COP for design and construction of steel chimneys ---structural aspects
SP-47 Handbook on structures with steel lattice portal frames
SP-38 Handbook for typified designs for structures with steel roof trusses and construction
SP-40 Handbook on structures with steel portal frames
SP-6 ISI Handbook for structural engineers
SP-6(1) Structural steel sections
SP-6(2) Steel beams and plate girders
SP-6(3) Steel columns and struts
SP-6(4) Use of high strength friction grip bolts
SP-6(5) Cold formed light gauge steel structures
SP6(6) Application of plastic theory in design of steel structures
SP-6(7) Simple welded girders
SP-7 National building code of India (part6/Section 6 covers steel)
IS 2314 : Specification for Steel Sheet Piling Sections
IS 1566 : Specification for Hard-drawn Steel Wire Fabric for Concrete Reinforcement
IS 1785 : Part 2 : Specification for plain hard-drawn steel wire for prestressed concrete: Part 2 As drawn wire
IS 1785 : Part I : Specification for Plain Hard-drawn Steel Wire for Prestressed Concrete - Part I : Cold Drawn Stress-relieved Wire
IS 1786 : Specification for high strength deformed steel bars and wires for concrete reinforcement (superseding IS:1139-1966)
IS 2090 : Specification for high tensile steel bars used in prestressed concrete
IS 3954 : Hot Rolled Steel Channel Sections for General Engineering Purposes - Dimensions
IS 3964 : Light rails
IS 4000 : Code of practice for high strength bolts in steel structures
IS 432 : Part 1 : Specification for mild steel and medium tensile steel bars and hard-drawn
steel wire for concrete reinforcement: Part I Mild steel and medium tensile steel bars
IS 432 : Part 2 : Specification for mild steel and medium tensile steel bars and hard-drawn
steel wire for concrete reinforcement: Part 2 Hard-drawn steel wire
IS 4948 : Specification for welded steel wire fabric for general use
Misclleneous
IS 1038 : Specification for steel doors, windows and ventilators
IS 10451 : Specification for steel sliding shutters (top hung type)
IS 10521 : Specification for collapsible gates
IS 1361 : Specification for steel windows for industrial buildings
IS 10790 : Part 1 : Methods of sampling of steel for prestressed and reinforced concrete part 1 Prestressing steel
IS 10790 : Part 2 : Methods of sampling of steel for prestressed and reinforced concrete Part 2 Reinforcing steel
IS 1081 : Code of practice for fixing and glazing of metal (steel and aluminium) doors, windows and ventilators
IS 11309 : Method of conducting pull-out test on anchor bars and rock bolts
IS 1173 : Hot rolled slit steel tee bars
IS 1252 : Dimensions of hot rolled steel bulb angles
IS 12817 : Specification for stainless steel butt hinges
IS 1341 : Specification for steel butt hinges
IS 3843 : Specification for steel back flap hinges
IS 13519 : Guidelines for inspection of fixed steel offshore structures during fabrication and installation
IS 1495 : Specification for mild steel dust-bins
IS 1852 : Rolling and cutting tolerances for hot rolled steel products
IS 1863 : Hot rolled steel bulb flats
IS 1864 : Hot-rolled steel L-sections for shipbuilding
IS 2546 : Specification for galvanized mild steel fire bucket
IS 3312 : Specification for steel shelving cabinets (adjustable type)
IS 3313 : Specification for Steel Filing Cabinets for General Office Purposes
IS 3314 : Specification for steel clothes lockers
IS 3489 : Specification for enamelled steel bath tubs
IS 3497 : Specification for steel wardrobes (adjustable type)
IS 4351 : Specification for steel door frames
IS 7196 : Specification for hold fast
IS 5187 : 1972 Specification for flush bolts
IS 5822 : 1994 Code of practice for laying of welded steel pipes for water suypply
IS 775 : 1970 Specification for cast iron brackets and supports for wash basins and sinks
IS 7760 : 1985 Specification for steel glass-front cabinets
IS 7761 : 1983 Specification for steel book cases
ALUMINIUM
3908 Aluminium Equal Angles
3909 Aluminium Unequal Angles
3921 Aluminium Channels
IS 6449 : Aluminium bulb angles for marine application
5384 Aluminium I-Beams
6445 Aluminium T - sec
8081 Specifications for slotted sections
IS 1948 : Specification for aluminium doors, windows and ventilators
IS 1949 : Specification for Aluminium Windows for Industrial Buildings
IS 4571 : Specification for Aluminium Extension Ladders for Fire Brigade use
IS 6475 : Aluminium tee bars for marine application
IS 6476 : Aluminium bulb plates for marine application
IS 8147 : Code of Practice for Use of Aluminium Alloys in Structures
CAST IRON RELATED
IS 1726 : Specification for cast iron manhole covers and frames
IS 5455 : Specification for cast-iron steps for manholes
IS 5961 : Specification for cast iron gratings for drainage purposes
IS 6280 : Specification for sewage screens
Posted: Fri Jul 16, 2021 8:00 am Post subject: |
Dear Engineers
List of few important IS Codes
Special Structures related
Ports & Harbours
9527(pt1) cop for design and construction of port & harbour structures--conc monoliths
9527(pt3) cop for design and construction of port & harbour structures--sheet pile walls
9527(pt4) cop for design and construction of port & harbour structures--cellular sheet pile walls
4651 cop for planning and design of port & harbour structures (5 parts)
IS 4651 : Part 1 : 1974 Code of practice for planning and design of ports and harbours: Part 1 Site investigation
IS 4651 : Part 2 : 1989 Code of practice for planning and design of ports and harbours: Part 2 Earth pressure
IS 4651 : Part 4 : 1989 Code of practice for planning and design of ports and harbours: Part 4 General design consideration
IS 4651 : Part 5 : 1980 Code of practice for planning and design of ports and harbours: Part 5 Layout and functional requirements
IS 4651 : Part III : 1974 Code of Practice for Planning and Design of Ports and Harbo
10020 recommendations for design and construction of port & harbour components--slipways
13746 geotechnical investigation of off-shore jacket structures
4111(pt3)cop for ancillary structures in sewarage system--pumping stations and pumping mains
2751 recommended practice for welding of plain and deformed bars for rc construction
9417 recommendations for welding cold worked deformed bars for rc construction
2204 cop for construction of reinforced concrete shell roof
2210 criteria for design of reinf. Conc. Shell structures and folded plates
2750 steel scaffoldings
10262 recommended guidelines for conc mix design
3935 cop for composite construction
4090 criteria for design of reinforced concrete Arches
4091 cop for design and construction of foundations for transmission towers
11233 cop for design and cons of Radar antena,Microwave TV Tower station
4995 criteria for design of reinf. Conc. Bins for storage of granular and
powdery materials (2parts)
9178 criteria for design of steel bins for storage of bulk materials (3parts)
4998 criteria for design of reinforced concrete chimneys
6533(pt1) cop for design and construction of steel chimneys--mechanical aspects
6533(pt2) cop for design and construction of steel chimneys ---structural aspects
11504 criteria for structural design of reinf conc. Natural draught cooling towers
11561 cop for testing of cooling towers
11682 criteria for design of RCC staging for overhead water tanks
12303 criteria for design of reinf. Conc. Hinges
13591 criteria for design of lifting beams
14458(pt1) retaining walls for hill area---selection of type of wall
14458(pt2) retaining walls for hill area---design of retaining/breastwall
14458(pt3) retaining walls for hill area--construction of dry stone wall
8686(pt1) cranes -design principles for loads and loads combinations--general
8686(pt5) cranes -design principles for loads and loads combinations---OHT and portal bridge cranes
14467 cranes --wind load assessment
5525 recommendations for detailing of reinf. In reinforced conc. Works
6494 Water proofing of UG Reservoir and swimming pools
13301 cop for vibration isolation of Machine foundations
5525 Recommendations for detailing of RC Structures
6505 cop for installation of joints in conc pavements
7861 Extreme weather concreting
IS 4996 : Specification for reinforced concrete fence posts
6922 criteria for safety and design of stuctures subjected to UG Blast
4991 criteria for blast resistant design of structures for explosion above ground
2553 Specifications for SafetyGlass
Posted: Sun Sep 19, 2021 2:58 am Post subject: |
BOOK
PRINCIPLES OF STRUCTURES BY K J WYATT - Revised Edition
UNIVERSITY PRESS
It is very thin book , 152 pages , on structures basics . Presentation seems very good.
Useful for students aspiring to be structural engineers , budding designers as well as ignorant veterans like me.
Purchased at cost of Rs 150 , years back from Delhi book fair - 2007.
VPandya General Sponsor
Posted: Wed Dec 08, 2021 11:10 pm Post subject: Advanced Computer Modelling of Different Structures .l |
Dear Sefi Friends .
This topic is very useful in our work . I have this book in .pdf format but I do not know to attach a .pdf file here.
" Advanced Computer Modelling of Different Structures . "
Regards .
Vasudeo Pandya P.E.
Structural Engineer
A Book on Computer Modelling of Structuresc. |
62.05 KB |
Viewed: |
88 Time(s) |
Meera P SEFI Regulars
Posted: Thu Dec 09, 2021 8:30 am Post subject: Some useful References |
Sir,The book : " Advanced Computer Modelling of Different Structures . "
You can send it on my e-mail address :
meera.p.p@gmail.com (meera.p.p@gmail.com)
Thanks and regards
meera p
Posted: Fri Sep 23, 2022 1:29 am Post subject: |
Few references on Hydropower Structures are as given herein below:
Handbook of Hydroelectric Engineering by PS Nigam
Hydropower Structures by RS Varshney
Tunneling in Weak Rocks by Bhawani Singh and RK Goel
BIS CODES ON TUNNELING ( Tunnel supports , tunnel Lining , Grouting)
US ARMY CORPS OF ENGINEERS ( USACE ) PUBLICATIONS ( codes)
Central Board of Irrigation and Power ( CBIP) MANUALS
A book on Developments of SMALL HYDROELECTRIC PROJECTS IN HILLY REGION by Er PURA TUPE Nabhi Publications
Papers by Hoek and Brown available on internet
24.09.2022 - SOME MORE REFERENCES :
- Teacher's Manual
HYDROPOWER ENGINEERING For Diploma level Courses
For Deptt of Technical Education, Govt of Uttarakhand
(Alternate Hydro Energy Center , IIT ROORKEE)
- A TEXT BOOK OF WATER POWER ENGINEERING
( INCLUDING DAMS ENGG , HYDROLOGY AND FLUID POWER ENGG)
Authors - RK SHARMA , TK SHARMA
S CHAND & COMPANY LTD
( Also available at Jain book Depot , Connaught Place ,opp Plaza Cinema, NDelhi)
- WATER POWER ENGINEERING
Authors - M M DANDEKAR , KN SHARMA
Vikas Publishing house , (also available at jain book depot)
- HYDRO ELECTRIC AND PUMPED STORAGE PLANTS
Author - MG JOG
NEW AGE INTERNATIONAL PUBLISHERS
- ANALYSIS & DESIGN PRACTICE OF HYDRAULIC CONCRETE STRUCTURES
Author - KARUNA MOY GHOSH
PHI ( eastern economy edition)
Posted: Fri Sep 23, 2022 2:09 am Post subject: |
A posting from late respected Indrajit Barua Saheb regarding references of Books . He was always there to help engineers on sefi . He was classmate of our Octogenarian Structural expert Sri UH Varyani saheb ( Varyani saheb is still active and a great inspirer to engineers) .
ibarua wrote: | 21/7/2011
To be a design engineer, you have to be able to design in RCC, steel, as well as in PSC.
Books on RCC Design: RCC Designers' Handbook by C.E.Reynolds & J.C.Steedman
Limit State Design of R.C. by P.C. Varghese
Calculation, Design & Testing of R.C. by K.L.Rao
Handbook of Concrete Engineering edited by Mark Fintel
Books on Steel Design: Design of Steel Structures by N. Subramanian
Structural Steel Design by J.E. Bowles
Books on PSC design: Prestressed Concrete Structures by T.Y.Lin & Ned Burns
Design of Prestressed Concrete by R.I. Gilbert & N.C. Mickleborough
Prestressed Concrete by S.K. Mullick
Indrajit
