Er.shivani SEFI Member
Posted: Mon Aug 07, 2023 12:30 pm Post subject: rectangular hollow section purlins |
hii sir/mam,
I am designing a rectangular hollow section purlin.
what formula should we used to find plastic section modulus required to initially assume a section? can we use the formula given by gaylord as attached.
I cannot find any reference where clear design procedure of rectangular hollow section purlins is given as per IS800, it would be of great help if anyone could share the design procedure they follow to design SHS or RHS purlins.
Thanks in advance.
334.42 KB |
Viewed: |
57 Time(s) |
R_Shenoy SEFI Member
Posted: Tue Aug 08, 2023 12:30 pm Post subject: rectangular hollow section purlins |
Please download tech literature for tata hollow sections. It contains section properties, allowable stresses, etc.
On Tue, 8 Aug, 2023, 15:53 Er.shivani, <forum@sefindia.org (forum@sefindia.org)> wrote:
Thanks in advance.
Download Attachments:
Binoy Bhuson Saha SEFI Regulars
Posted: Wed Aug 09, 2023 6:30 am Post subject: rectangular hollow section purlins |
In my opinion instead of retangular hollow section you may use pipe section.If the purlin is used for roof top composit section suitable channel section braced with bend rod may be used.
On Tuesday, 8 August, 2023 at 03:52:18 pm IST, Er.shivani <forum@sefindia.org> wrote:
hii sir/mam,
Thanks in advance.
http://www.sefindia.org/forum/files/img_20230807_174848_156.jpg
durai_sundaram General Sponsor
Posted: Wed Aug 09, 2023 7:30 am Post subject: rectangular hollow section purlins |
The same formula is given in Page 477 ( design of beams) in the book " Design of steel structures - Limit state method " by Dr. N.subramaniam.
M.Durai
On Wed, Aug 9, 2023 at 12:09 PM Binoy Bhuson Saha <forum@sefindia.org (forum@sefindia.org)> wrote:
Quote: | In my opinion instead of retangular hollow section you may use pipe section.If the purlin is used for roof top composit section suitable channel section braced with bend rod may be used.
On Tuesday, 8 August, 2023 at 03:52:18 pm IST, Er.shivani wrote:
hii sir/mam,
Thanks in advance.
Manas M Ghosh Bronze Sponsor
Posted: Wed Aug 09, 2023 8:11 am Post subject: Zp of RHS, SHS |
The Values of Zp for RHS, SHS are available in Pages 796-796 of the book Design of Steel Structures by Dr N Subramaniun.
MMGhosh
mmg SEFI Member
Posted: Wed Aug 09, 2023 8:30 am Post subject: rectangular hollow section purlins |
MMGhosh
On Wed, Aug 9, 2023 at 12:42 PM Binoy Bhuson Saha <forum@sefindia.org (forum@sefindia.org)> wrote:
hii sir/mam,
Thanks in advance.
svgkrao SEFI Member
Dear all,
As per IS 800, RHS /SHS come under closed section. I designed RHS 150x100x3.6mm for 7.5m span purlins as per IS 800 last year and executed the project. The owner and erection contractor appreciated RHS pulins after seeing some issues of Z purlins in surrounding sites.
On Wed, 9 Aug 2023, 12:49 Binoy Bhuson Saha, <forum@sefindia.org (forum@sefindia.org)> wrote:
hii sir/mam,
Thanks in advance.
Posted: Wed Aug 09, 2023 8:52 am Post subject: rectangular hollow section purlins |
thanks all for your reply
sir, my question is,
as in case of channel or i section purlins we have a formula (as attached previously) to get plastic section modulus required and from there we assume a suitable section whose plastic modulus is greater than the required value.
In the same way do we have a formula to find required section modulus for square/ rectangular hollow sections.
Posted: Wed Aug 09, 2023 9:26 am Post subject: Zp of RHS, SHS |
Sir,
Can you share me the basis of the formula?
Zp of RHS and SHS are also listed in IS 4239.
MMGhosh
Posted: Wed Aug 09, 2023 9:39 am Post subject: rectangular hollow section purlins |
the formula is given for channel and i section purlins in "Design of steel structures:Limit state method,N subramanian "
it is given on page no 480 equation 10.63
also it is used in example 10.11 of the book on page no 493-494
