Improvement of SBC
rayeesnaqashbandi
PostPosted: Fri Sep 01, 2023 10:30 am    Post subject: Improvement of SBC Reply with quote
Respected all
Kindly provide valuable guidance how to calculate the bearing capacity after providing stone piling in loose soil strata
The NSBC of particular area is 3.3t/sqm
But I need to improve the value to 7.0t/sqm
CEng Rayees Naqashbandi
M. Tech (Structural Engineer) B.E. (Civil Engineering)
+919419018103
Mueed rasool
PostPosted: Fri Sep 01, 2023 4:30 pm    Post subject: Improvement of SBC Reply with quote
Sure sir.You can contact on me on 9906921840.
Mueed Rasool
On Fri, Sep 1, 2023, 7:21 PM rayeesnaqashbandi <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
gondelamahesh
Please share related site pic
On Fri, 1 Sept 2023, 16:50 rayeesnaqashbandi, <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
KANNAN.M
PostPosted: Fri Sep 01, 2023 10:30 pm    Post subject: Improvement of SBC Reply with quote
Try with plate load test.
On Fri, Sep 1, 2023, 9:23 PM rayeesnaqashbandi <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
lagnajit das
PostPosted: Sat Sep 02, 2023 8:30 am    Post subject: Improvement of SBC Reply with quote
You may adopt Under reamed pile.
On Sat, 2 Sep, 2023, 3:37 am rayeesnaqashbandi, <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
KANNAN.M
PostPosted: Sat Sep 02, 2023 3:30 pm    Post subject: Improvement of SBC Reply with quote
I have suggested try  the plate load test.Kannan.MKarthick Associates
Chennai
9486100506
On Sat, Sep 2, 2023 at 3:48 AM karthi associates <karthickassociates61@gmail.com (karthickassociates61@gmail.com)> wrote:
           Respected all
+919419018103
sspawar
PostPosted: Sun Sep 03, 2023 12:53 am    Post subject: Reply with quote
You have to assess bearing capacity of group of stone piles and the sum of  NSBC and stone pile group may be increased by add more stone piles to attain required SBC.
following literature may helpful for you
Estimation of bearing capacity of floating group of stone columns.pdf
 Filename:  Estimation of bearing capacity of floating group of stone columns.pdf
 Filesize:  357.76 KB
 Downloaded:  78 Time(s)
1492431565-39 IGC 1996, Delhi-Gravel_Piles-Construction&Field_Testing.pdf
 Filename:  1492431565-39 IGC 1996, Delhi-Gravel_Piles-Construction&Field_Testing.pdf
 Filesize:  1.16 MB
 Downloaded:  178 Time(s)
Bhimaji Dashrath Kanawade
PostPosted: Sun Sep 03, 2023 8:30 am    Post subject: Improvement of SBC Reply with quote
Respected sir,
Very low SBC means, might be it is dumping ground in past.
Remove all soil upto min 1m. Use stones, gravels material. For overall part, do compaction. Stabilize soils with chemicals, grouting materials.
Thanks & Regards
On Fri, 1 Sept 2023, 4:50 pm rayeesnaqashbandi, <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
glnp12
PostPosted: Mon Sep 04, 2023 5:30 am    Post subject: Improvement of SBC Reply with quote
Sir,
It is not clear, as indicated...stone piling....
Is it stone column by coarse aggregate and vibro-compaction ? This method has many uncertainties.
It is difficult to justify the prediction of SBC by any empirical / numerical methods. Better to go with field testing. Contractor, may promise many things. But designer should ensure SBC with adequate FoS.
With 3.3 t/sq.m., it seems to be marshy land. There will be difficulty to contain the stone column material properly. With application of load, it may start bulging and collapsing at the final load.
Is it possible to give more details about type of soil, ground water level, etc. ?
One should be extremely careful in such cases.
G. Prabhakar.
On 01-09-2023 04:46 PM, rayeesnaqashbandi wrote: [quote]  Respected all Kindly provide valuable guidance how to calculate the bearing capacity after providing stone piling in loose soil strata The NSBC of particular area is 3.3t/sqm But I need to improve the value to 7.0t/sqm   Regards  CEng Rayees Naqashbandi M. Tech (Structural Engineer) B.E. (Civil Engineering) +919419018103     --
RENJERLA
PostPosted: Mon Sep 04, 2023 6:30 am    Post subject: Improvement of SBC Reply with quote
Dear Nagashbandi,
Please refer to the Professional Standard "JGJ 79-2012, Technical Code for Ground Treatment of Buildings" for composite foundation calculations.
ravikumar
On Fri, Sep 1, 2023, 11:43 PM rayeesnaqashbandi <forum@sefindia.org (forum@sefindia.org)> wrote:
           Respected all
+919419018103
