Rectangular Hollow Section biaxial design is800 2007
arif_rubin
PostPosted: Fri Mar 01, 2024 10:16 am    Post subject: Rectangular Hollow Section biaxial design is800 2007 Reply with quote
I have modelled an FOB withportal over plate girder supporting utilities at top beam. I have adopted RHSsection for portal (Column and beam).<o></o>
Instaad design result, for combined action, it considers utility ratio as per cl9.3.2.2 equation 2. Why is it not considering the utility ratio with equation1. For I-section, it provides the results with both the equation. As per manualcalculaation, the utility ratio with equation 1 is 40% higher, but I could notfigure out.<o></o>
I triedfinding the reference if for box section (rectangular), equation 1 can beignored or not. Please guide me with your views and knowledge.<o></o>
FOB_Simply_Beam type_5Gir_Pedes.pdf
 Filename:  FOB_Simply_Beam type_5Gir_Pedes.pdf
 Filesize:  37.03 KB
 Downloaded:  42 Time(s)
